How will I know when the 12 volt battery needs replacement?
JSW
Ann Arbor
Chevy Bolt; Porsche Boxster; Chevy Blazer; Jeep Wrangler
There are several safe methods. The cheapest is the two holes and furniture plug method. There is also the method @markboris used in placing a bulkhead connector inside the charge port. There's also the much more expensive route that I took (but it's really intended for doing FDRS updates, not trickle charging): ??
Although I like your approach more, my approach from early 2021 was easy and free…
Ford Mustang Mach-E How will I know when the 12 volt battery needs replacement? IMG_3659
Ford Mustang Mach-E How will I know when the 12 volt battery needs replacement? IMG_3661
Stanmckinney
Stan
Campbellsville, Ky.
1966 Mustang convertible
I am not mechanically inclined and learned a long time ago to not touch a car’s mechanicals or electrical system. Can you provide details on how to do both and who might be trusted to do it? Would either impact warranty?
GreaseMonkey
Chicago, IL
24 Mach-E GT
Rick, Thanks for your input. Always looking at Plan B’s, even if never implemented. The tire issue was for our Q5, not the MME.
Love the ā€˜Stang (my first was a ā€˜65 blue pony convertible bought in 1970) but I do get a teensie bit nervous these days about being stranded, for any reason.
Any handy person can do it. If you’re concerned about the 12v, have someone make the mods and buy a good quality 12v charger. I got one from Amazon for $47. It’s worth the peace of mind.
I found the video. No way I would attempt that. If the battery fails, guess I will just call Ford.
Cutting holes in plastic? Hole saw on drill.
kennethjk
Ken
MME Prem. EB 4WD, X3, IX50
I have had cars way longer than 3 years and have not replaced the 12v battery.
What am I missing that batteries are changed so early?
Changed early? By Ford?
kennethjk
Ken
Sorry , meant replaced by people. I had a Macan for 7 years and 67k miles and battery operated just fine. I never tested it but worked ok.
If you’re genuinely careful and don’t try to manhandle or force the drill you can actually do it without removing the covers. Apparently though, we need to discourage such ludicrous ideas.
kennethjk
Ken
I cut the holes without removing the covers. No big deal, just do it delicately
Some people take things to the absurd. I can tell you that on the F-150 forum, a large number of people replace batteries without load testing them, often while in warranty. I don't get it. Lack of commonsense IMO.
Teslaeata
Nottingham, England, UK
Drive the damned car and quit worrying about it.
THIS THIS THIS THIS THIS
The more you f**k about with it the greater chance you’ll eff it up.
jpblincoln
2021 Mach E
In early January my dashboard said 12V battery too low for heat and there was no heat. I took it to the ford dealer and since I have over 40K I had to buy a new battery.
