Insane charging noise
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
FYI for all: Price of a kWh is the same whether delivered slowly or quickly unless you have off-peak rates.
Not if your utility has a demand charge...
agoldman
Charleston, SC
How was the noise at 40 amps?
If it's very hot in the garage, horrible. feels like the car is going to catch fire and blow any second, but it gets through it. Mostly if the garage is boiling hot and closed.
Holy Driver
Lars
Germany
Mustang Mach-E RWD SR
Any news?
In our german forum are some users with cars what have loud noises with AC charging with any amperes from 6 to 16A with 3phases.
ODBMongoose
ODBMongoose
Niels
Netherlands
SR RWD Mach-E Star White Tech Pack Plus
Any news?
No Ford expects to provide a solution end of August / September.
Were all eagerly awaiting
BMT1071
Glendale, AZ
Strato
Strato
Netherlands
Ford Mustang Mach AWD ER
I commend you for your patience. Have my MME for 4 days now, and am already fed up with it. I have no garage so need to charge in front of the house. Before charging in daytime I have to check with my neighbour (works night shifts) and charging during the evening/night is impossible because the sound level exceeds legal limits. Totally unacceptable. Will need to reduce the wall box output, it is now 11kw. And that doesn't make my wife very happy, her Tesla M3 is dead quiet when charging. Let's hope Ford resolves this shortly.
Other than that, I am a happy MME-driver:)
Some 2021 Mustang Mach-E vehicles built on or before 11.08.2021 (build code MG) may exhibit a strong fan noise whilst charging in level 3. Noise occurs when charging current is approximately 10.5 kW or above.
Ford Mustang Mach-E Insane charging noise 1629377493968
Ford Mustang Mach-E Insane charging noise 1629377476482
Ford Mustang Mach-E Insane charging noise 1629377454500
Interesting that there's now "a fix". I will have to have my dealer apply it.
prdude
pleasant ridge, MI
engineer
Interesting that this refers to "level 3 charging". At least in North America, "level 3" means DCFC ....... maybe, in Europe "level 3" means three-phase charging ...... or did the author make a typo?
No, if you read the details it discusses charging above 10.5 kW. It may not help with the overly-loud L2 charging problem but then again it might.
Mach-EMark
Marky
Long Island, NY
2021 Mustang Mach-E Premium AWD STD Battery
I just installed a Chargepoint Homeflex yesterday, hard-wired, 60 amp breaker. I selected 60A on the Chargepoint App and my Mach-E was charging at 11.25 kW. Quiet in the beginning, then a steady "portable generator" type loud noise. I had to stop charging before my neighbors could complain. I selected 50 amp breaker on the App, getting 9.4 kW, no noise. Keeping my fingers crossed.
BMT1071
Glendale, AZ
They also use the term "mode 3" and mention a specific kWh. The term "wallbox" is used, which I have only seen from UK/EU forum members. If I had to guess I would say this update is designed to address both L2 charging above 10.5 kW and L3.
