installing a liftgate C263
tomtel
Tomasz
Poland
Mustang Mach-e GT Performance, Ford EDGE ST
mechanic
Hey.
I'm installing a hands-free liftgate system and I'm looking for connectors.
Do you know where the C263 connector is (what the wire connector looks like) and where the S319 and S335 points are?
Ford Mustang Mach-E installing a liftgate C263 IMG-20250310-WA0026(1)
tomtel
tomtel
Tomasz
Poland
mechanic
Thanks. That will help me ?
When it stops raining I'll go look for it ?
tomtel
tomtel
Tomasz
Poland
mechanic
I'm still looking for a place where I can find a 12V power supply to power the liftgate module.
Can you check the 12V connection to the TCU?
I think that's where I'll have the closest constant 12V
I’m in a plane and can’t check anything until later today. Where are you wanting to pick up the 12V. In what area of the car?
tomtel
tomtel
Tomasz
Poland
mechanic
Thanks for your help, there is no rush :)
Ideally in the trunk, rear left side (area in the picture)
Ford Mustang Mach-E installing a liftgate C263 Screenshot_20250323_171511_Gallery
tomtel
tomtel
Tomasz
Poland
mechanic
I managed to add the liftgate module.
Everything works fine when I have the key with me. The problem is with opening it if I use the key's phone. It doesn't always react, as if it doesn't recognize me.
Is this normal? Do you have the same?
kens
Ken
IL, USA
2022 GT
My PAAK doesn’t always react fast when opening the drivers door either, sometimes it needs extra presses. Otters have mentioned if it's in a back pocket it may have trouble.
