MacherAWD
- Erik
- Mar 29, 2022
- North Shore MA
- 2021 AWD Select C&T, 2020 Bolt Premier
- Healthcare Software
I have this, I do the same 2hr, mostly highway drive quite often, I think it calibrates based on factors like speed tolerence, so I had that set to 7mph over, and Maine is 70mph speed limit, so the car assumes I will be driving 77 the whole way and lowers its estimate. Last weekend, I ended up driving 70 most of the way and found myself going much further than predicted.Doesn’t really seem any more accurate.
If anything it’s still reading really low.
This morning it dropped 30 miles and said “range adjusted due to outside temp.” I was in the garage in the morning and it’s low 80s outside.
I also tried resetting my driving history a week ago to see if that would help. Then I also took some longer drives (averaging 2.6 mi/kWh) and my GOM still stayed low.
When I reset the driving history, I went to 240 miles at full charge. After driving less than 30 seconds…… it dropped to 180.
Something else is definitely going on if it’s not using your driving history to give range estimates…..
