DaMeatMan
- Joe
- Feb 26, 2021
- Toronto, ON, Canada
- Mustang Mach-E Premium AWD Extended Range Battery
So I just installed a PureFlow air filter in my Mach-E, and you guys should know that there is a very noticeable impact to the flow of air coming out of the vents. Basically I need to kick the fan 1 speed higher to get the flow that u used to get.Pure Flow Air now lists a compatible air filter for the 2021/2022 Mach-E.
https://pureflowair.com/products/2022-ford-mustang-mach-e-cabin-air-filter-pc99542x
When you look at the construction of the filters this makes sense, since the stock Mach-E filter is essentially like a thin sheet of coffee filter that was likely designed with AIR FLOW EFFICIENCY in mind. While the PureFlow has many layers, is much thicker and was designed with PARTICULATE CAPTURE in mind.
Basically if you're on the fence right now you need to decide how important the quality of air is to you, versus the actual strength and flow of air.
For me personally I have only driven with the PureFlow for about a week, but I think I'm OK to kick the fan speed a tad bit higher knowing that the cabin air quality is actually being filtered properly. I personally have year round allergies and I'm often congested, so this sort of thing is important to me. I also noticed that even smells are cut down significantly and near non existent when driving past obvious oil burning vehicles or trucks. Whereas previously the stock filter Basically did nothing at all, and what I smelled I'm the cabin was literally no different from having the windows rolled down smelling the outside air.
