JohnFoxeSheets
- John
- Jan 29, 2022
- San Francisco
- Website
- johnfoxesheets.com
- 2022 Iced Blue Silver Mach E GT
- Retired Engineer
I was asked if I would try to design a jack pad that could be installed permanently at each of the jack points on the Mach E. The goal is to make a pad that will fit with (hopefully) most floor jack saddles and can be left on the car at all times. While I've not made samples, I have made sufficient measurements that I'm fairly confident that this design will work. That said, I make no guarantees.
If anyone is interested in this design, I'm happy to make the 3D CAD files available. DM me if you're interested. If you have any ideas for improvements, please let me know.
This is the Jack Pad. It is used in conjunction with an Anchor which holds it permanently to the jack point. You would install four Pads and Anchors, one set at each jack point.
This is the anchor (not to the same scale).
Here are the Pad and the Anchor along with the screw that prevents the Anchor from slipping out.
This is looking "inside" the frame to see how the Anchor works during installation; it fits into the jack point hole and the Pad and Anchor are then slid so that the screws are against the edge of the hole.
The screws are then tightened and a third screw is installed to prevent the assembly from slipping.
There are two threaded holes in the Pad. The one closer to the double set of holes is for the front jack points, while the one further away is for the rear jack points with their slotted holes.
