Liftgate internal activation
Debof
Chicago
MME
Atttorney
Has there been any discussion about moving the internal activation button from the controls screen to be accessible from any screen? It drives me a little nuts that if I'm driving home from the grocery story and listening to music that I have to switch screens to open the liftgate when I get home.
load97
No3ne
Has been discussed. It probably won’t happen. And yes, it sucks the way they did it.
Ford_orr
orr
Los Angeles
2023 Mustang Mach E Premium AWD
Hellraiser
I second Jeff's post. I did this mod as well and use it all the time. There's three ways to get this thing to work with a physical button - replace one of the buttons in the lower-left instrument cluster, add a momentary button/toggle to the center console, or repurpose the useless "Parking" button, also on the center console. I chose the '"parking" button.
One of the best and practical mods you can do. I'm sure Mr. Boris will be along shortly to give you more information 😀
markboris
Sonora, CA
No I won't be because you gave all the information needed.
I install one of these physical liftgate momentary switches in most the Mach-E's that have come here for suspension work. Not sure if they are happier with the new suspension or liftgate switch. Seems to be a toss up. 🤣
IgorKl
Pacifica, ca
'22 MME CaliRoute 1 AWD and '25 MME Premium RWD Ext
The internal button is very useful. I use it very often, but mine came from autoease liftgate kit :)
@markboris , I would vote for suspension since I can control liftgate from key fob or app, but unfortunately no control to suspension from key fob :)
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
ReverendPete
Pete
Denver, CO
2023 MME Premium, 2018 Toyota Highlander Hybrid
Software Developer
I will also advocate for installing an internal button. I did very much like the first post in that thread, and installed one on the front of the center console. Very handy, and I use it 5-6 times a week!
I wish that Ford had spent the $5 that I spent on installing that switch, and built it in like a normal car. I think the car manufacturers are finally coming around to the realization that physical switches for things that are accessed a lot are a good idea again... slowly...
SonicBlue
Karim
Chicago
2021 Mach E
Lol. Yes, it’s been “discussed.” By which I mean I’ve probably yelled about this at least 4-5x per year for the past five years. Including posting, calling, emailing, etc.
And we’re certainly not the only ones to request this. Ford just doesn’t seem to care or has a reason they’re not sharing for why they won’t pin this to the top ribbon.
I’ll say it again: opening the trunk is not a “setting.” And it is cuckoo bananas that there are two one-tap means of activating max defrost but not a single one-tap means of opening the trunk.
kjlebleu
Kathy
Morgan Hill, CA
2025 Mustang Mach E
Accounting
