Lighted Pony in Front grill area
methorian
Roanoke, VA
IT Admin
I have hopes we may eventually see options to retro the lighted pony! I would imagine the non-GT models will be lacking the wiring harness for the lighted pony though too, which may make retroing it a little more difficult.
markystarky
Marc
Ventura, CA
2021 MME, 2011 Honda Ridgeline, 2002 Chrysler Conv
looks like only '1' bolt holds the Badge in place. If the bolt is easy to access... then it should be simple to replace. However, I have yet to find a Ford Part# for it:
Blanked, this is a perfect exploded view of the front. Where did you find this?
TheVirtualTim
Dearborn, MI
The car built for sale in China also has an illuminated Pony. The front-end trim on that car is the same (or at least very similar) to the GT.
Yeah, but I'm sure it also has a different wiring harness. Probably the same wiring harness the GT has. Non-GTs won't have the correct wiring harness or fuses. About the only way we'd get an illuminated pony is with a glow stick or an AA battery :D (I am not butchering my car's electrical system like those radar detector people do.)
TheVirtualTim
Dearborn, MI
Yeah ... so I DID ASK if it was the same wiring harness (hoping the cars were pre-wired). Sadly... not the same wiring harness. So we are not pre-wired. ?
FPLiptak
Frank
Saint George, UT
Mach-E Premium ER AWD
Batteries!!
Someone needs to come out with a Mach E pony with the inside filled with PV chip, LED lighting, with motion detector and a small battery in the attachment mechanism behind the nose.
Luke
Luciano
MA, USA
Mustang Mach e, Taurus
Computer Engineer
Tapping into the headlight plug using a Y splitter pigtail, so no splicing of the original cables.
Maybe something like this (of course we need to check what the MME uses for plugs...I hope they use plugs :p):
Ford Mustang Mach-E Lighted Pony in Front grill area 1619465376139
I wouldn’t want to mess with something critical like headlamps. Perhaps the emergency escape switch power?
Luke
Luciano
MA, USA
Computer Engineer
I don't want the parachute (hood) open at me while driving ?, no secondary mechanical lock there.
Ok, the front trunk light. Can’t get more innocuous than that ?
Frunk light presumeably goes out when the Frunk is closed. Please climb in and close behind you to test. We'll await results.
