Locking the car, using the door lock button
circatee
Georgia, USA
Mustang Mach-E GT PU, 2025
Is it just me, or is it often a hit and miss, when you press the lock button on the driver door?
Honestly, I feel I need to press the thing a few times.
Thoughts...
AZBill
Works for me. I have seen it take a couple of tries, but that is very rare.
Thoughts...
When you press the button it pings your fob or PAAK, if it doesn't get a response it won't lock the doors. If that happens, try standing back further from the car or the rear lock button instead.
[7-8] + [9-0] always works.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Retired Engineer
Teslaeata
Nottingham, England, UK
Thoughts...
THIS - yep, it’s the shopping trolley syndrome program this car has embedded!
Does what it likes, goes where it wants, when & how it wants.
The suspense of never knowing what happens/works next and when is the spice of the ‘Stang owner’s life ?
Works fine for me dnd always has.
Thoughts...
People have been reporting the same behavior for years. But it usually works fine for me. Not sure why it’s different for some.
Open door. Hit INTERNAL lock button. Close door.
santa fe,nm
www.envirokarma.org
Solar Sales/install
Thoughts...
inside drivers door lock always works for me...... outside pillar codes sometimes are hard to activate.
TGIF
IA
I just always hit the inside door lock as I’m getting out of the car. I hear the confirming beep when I get a few feet away.
BudC
Bud
St. Peters MO
2022 Mach-E Select RWD 2024 Kia EV9 GT-Line AWD
Try waiting for a count of say, three, before you press the button...that seems to work for me.
KAustin
WDC
Kia Telluride
The problem is it isn't a push button. Swipe your finger across the lock symbol. It should increase the functionality to 90%.
I’m very happy with walk away lock. Just make sure all doors are closed before you walk away.
Naah, that also fails quite a bit for me. I just hit the button on the inside door panel. It *always* works. ?‍♂?
