Lost 4% Battery Without Driving
mamejunkie
Orange County, CA
Premium Mach-E '21, Premium Mach-E '22
I doubt this is normal. Didn't drive the car all day yesterday, started at 90% charged and last night I noticed it was at 86% via the FordPass app. What would cause a drop like this? Did go out and check that it wasn't on or on some weird mode. Was locked. Strange it didn't unlock when I approach with the fob.
mark360
North Carolina
Tesla Model 3 AWD(OLD), Ford Raptor
Manufacturing
Was it at 86% this morning? That would sound about normal depending on if your car, most cars lose about 2% of battery per 24hr period.
mark360
North Carolina
Manufacturing
If it's cold outside the car will use power to keep the battery a certain temp as well, so there are some external factors to look at.
Mine does not lose anything overnight (so far) - parked in a garage heated to 50F.
mamejunkie
mamejunkie
Orange County, CA
In SoCal, outside low is 48. The MME is in the garage and its about 68.
TheVirtualTim
Dearborn, MI
Mach-E First Edition, Escape Hybrid
Was the car plugged in? When the car is not plugged in it will use the big battery to maintain the little battery. 4% sounds like a lot in 24
Do you leave your car plugged in?
Phantom drain is normal ... but probably not 4% in a day.
When the car is shut off, a lot of computer modules are put to sleep. But there are some modules that have to stay awake the whole time and those are always drawing power from the 12v battery.
There's a module that monitors the charge state of the 12v battery and it will periodically decide the 12v needs a charge. If the car is plugged in then it will draw power from your charger (AC power). If the car is not plugged in it will draw the power from the big battery -- and that's when you'll see the power drain (and that's normal).
I normally leave my car plugged in (and only charge it to 80%) when not using it so the 12v gets maintained from the house AC power. So I haven't got a good feel for how much daily drain is normal when it is not plugged in. I hear about 1%/day is probably normal.
Jimmy2
Jimmy
Wilmington NC
Wow, I had no idea that the big battery supplied charge to the 12v. I wonder if the 12v battery life gets extended as a result?
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
I didn't drive my car for a day, but kept it plugged in. Yesterday I went for a drive. The app reported it was still at 90% charge. When I got in, it reported 89% charge, and had dropped to 86% by the time I just backed out of the driveway. After that drop it went back to dropping normally. Seems like if the car is just sitting there it doesn't update the app with current SoC often. And possible the car doesn't check either since the dash dropped almost immediately after starting the car.
mamejunkie
mamejunkie
Orange County, CA
It wasn't connected at that time. Since its not cold here in SoCal, I just hit the current max (90%) and unplug it. Wait till I get to the ~50% before I plug it back in...a few days later.
No. If anything, it's the opposite. Not for that reason per se but because the 12v battery gets used a lot more in a BEV, like for heating and cooling (cabin and battery pack).
mark360
North Carolina
Manufacturing
Yeah I don't know then if it was parked in your garage. The normal rate is 2% per 24 hour period of phantom drain, unless it's really cold out. 4% isn't anything I'd get too worried about and it could just be a bug in their software. I'd just keep a close eye on it and if anything your service manager is only a call away.
Jimmy2
Jimmy
Wilmington NC
Forgive my ignorance: So there is no alternator in the MM-e?
There's a component that performs a similar function that charges the 12V from the 400v battery
Correct, no alternator. In an ICE car, an alternator is needed to convert the fuel (gas) to electricity. In a BEV, electricity is already the fuel. Much more efficient to just transfer electricity to the 12V battery from the high voltage battery.
