Mach-E Trunk gap alignment help
Sosrip27
Alex
2021 Mach E Premium AWD
Like the title says there is a large gap between the roof and the trunk spoiler on my 2021 MME Does anyone know how to adjust the trunk to make it flush with the roof?
Ford Mustang Mach-E Mach-E Trunk gap alignment help IMG_1744
VegStang
Leo
Silicon Valley
Volvo C40 Recharge, 2023 MME
I had a 21 and had it adjusted twice by the dealer and their body shop. I initially tried adjusting it myself with the bolts at the top but there really wasn't much play and it was never to the level where my 23 is at. https://www.macheforum.com/site/threads/trunk-door-allignment-adjustment-how-to-do-it.20157/ Sadly, I don't think you will be able to get it adjusted where it should be and I would consider it a manufacturing issue- but you may be able to improve it a little.
Like the title says there is a large gap between the roof and the trunk spoiler on my 2021 Mach-E. Does anyone know how to adjust the trunk to make it flush with the roof?
Hi Alex, you can't make it flush with the roof but you can lessen that gap better than what you have now. It is really simple. You just need to loosen the bolts on the mounting bracket, then push up on the back end of the liftgate which forces it to slide back on the mounting bracket which has elongated holes. While pushing back, tighten the bolts. Only do one mounting bracket at a time.
If yours is like mine was and the liftgate is also a little lower than the roofline, I installed one washer between the bracket and liftgate for each bolt. That brought mine up so it is level with the roof and rear quarter panels. If you do need to add washers, removing the bolts on either side is also easy to do and when both bolts are removed, the liftgate will not fall or anything, It stays in place as long as you don't remove the bolts on BOTH mounting brackets at the same time. Replacing the bolts takes a bit of juggling but you will get it. Also do not over tighten these bolts. They only get tightened SUNG to 22 lb ft.
What mine looks like after I added washers to level liftgate with roof and pushed it all the way forward to lessen the gap.
Ford Mustang Mach-E Mach-E Trunk gap alignment help IMG_0839
Washers I installed between mounting bracket and liftgate to level it with the roof
Ford Mustang Mach-E Mach-E Trunk gap alignment help IMG_0838
Ford Mustang Mach-E Mach-E Trunk gap alignment help IMG_0840
Movie of the adjustment there is in the mounting bracket. Push the liftgate up as high as you can which pushes it forward on the mounting brackets before you tighten the bolts.
Sosrip27
Alex
Hi Alex, you can't make it flush with the roof but you can lessen that gap better than what you have now. It is really simple. You just need to loosen the bolts on the mounting bracket, then push up on the back end of the liftgate which forces it to slide back on the mounting bracket which has elongated holes. While pushing back, tighten the bolts. Only do one mounting bracket at a time. If yours was like mine and the liftgate is actually a little lower than the roofline, I installed one washer between the bracket and liftgate for each bolt. That brought mine up so it is level with the roof and rear quarter panels. If you do need to add washers, removing the bolts on either side is also easy to do and when both bolts are removed, the liftgate will not fall or anything, It stays in place as long as you don't remove the bolts on both mounting brackets at the same time. Replacing the bolts takes a bit of juggling but you will get it. Also do not over tighten these bolts. They only get tightened SUNG to 22 lb ft.
Thank you so much for all this info this is exactly what I needed to see! I will try this and reply back with an update!!
Great! Glad I could help and let me know if you have any other questions about this.
VegStang
Leo
Silicon Valley
As I've seen many time before on this forum, @markboris gets the win. Luckily I didn't have to go to the washer solution on the 23, but they just replaced the entire tailgate and the dealer had to send it back 3 times due to misalignment. It looks pretty good, but the glass reinstall is now not level with the gate frame, the right side is almost against the paint and the left up noticeably.
Sosrip27
Alex
Okay so it’s not perfect but it’s a hell of a lot better! Still some adjusting to do!
Ford Mustang Mach-E Mach-E Trunk gap alignment help IMG_2141
I think it looks really good. You can't get it perfect but it is a lot better.
Teslaeata
Nottingham, England, UK
Mine was like this from the start in June 2021.
Not sure if it’s in my mind but I thought it has gotten worse over the nearly 5 years and 125,000 miles.
The tailgate fits perfectly elsewhere so wasn’t interested in trying to make the black part at top align with roof because I thought this is the spoiler and adjustment of tailgate would make it fit less well elsewhere so I just live with it.
Sosrip27
Alex
Mark, would you have any input on how to fix this? Going to attempt to remove it from the car and see if I can get it back together.
Ford Mustang Mach-E Mach-E Trunk gap alignment help IMG_2143
I'm assuming when you say "remove it" you are talking about the front bumper cover?
In this thread, a member replaced the shutter area without removing the bumper cover. For me, taking off the cover is a 20 min job then you have access to everything. Doing it without removing the cover would probably take longer but I wouldn't know since I don't have issues removing the cover.
https://www.macheforum.com/site/threads/mach-e-lower-grille-replacement.53502/#post-1078548
Below are instructions on how to remove the front bumper cover if you want to go that route.
Sosrip27
Alex
Thank you! Seems like it may be more trouble than it's worth at this point.
Sosrip27
Alex
Is it possible to remove just the lower bumper easily? I'm referring to the part in my picture that separated from the grill/shutter assembly with broken tabs.
The bumper cover is all one piece with parts attached to it from the inside. You basically need to remove the entire bumper cover to easily get back there to remove or replace any of the attached parts. There was a member that lifted the car and removed the splash cover underneath the car and got up in behind the bumper cover to the area you are talking about and did some work but I don't know exactly what he did and if it is the same as what you need to do. It is not difficult to remove the bumper cover, just a bit time consuming. I've pulled mine off a few times and on several other Mach-E's also. A couple of posts above, I attached the removal instructions from the Ford Service Manual.
Ford Mustang Mach-E Mach-E Trunk gap alignment help IMG_4158D
A friend/member came up for the weekend and yesterday, we removed his front bumper cover because he wanted to paint the lower trim area. Figured we could detach it from the cover and it would be easier to paint. Well, that did not happen. After taking the front bumper cover off, we found there were so many tab/clips holding that trim on that it was extremely difficult to take it off. Decided to just paint the trim piece while on the bumper cover.
Since you are not taking off the trim but want to reattach it, maybe you can lift the car and remove the large plastic under shield then you may be able to push that lower shutter grill area back into the bumper cover. Just a thought.
I took some photos yesterday in case you are interested in seeing what the backside looks like. I marked just a couple of the tab/clips but they are every few inches or so and very stiff so trying to pry them free could end up breaking the tabs.
Ford Mustang Mach-E Mach-E Trunk gap alignment help IMG_1944
Ford Mustang Mach-E Mach-E Trunk gap alignment help IMG_1945
Ford Mustang Mach-E Mach-E Trunk gap alignment help IMG_1947
Ford Mustang Mach-E Mach-E Trunk gap alignment help IMG_1948
