DBC
Don
Volt ELR
Sweet! Hopefully it will work well from the get-go. Not being sarcastic, just being a realistic early adopter.
dbsb3233
TimCO
Colorado, USA
Yep. Witness the FordPass app. Doesn't instill a lot of early confidence.
Remember that For hasn’t rolled out the entire Ford Pass app. I recommending withholding judgement until we see the whole thing.
dbsb3233
TimCO
Colorado, USA
Not sure if that's a good thing or a bad thing (knowing that this is what we're seeing with the simpler parts, and the more complicated stuff is yet to be added). ?
ClaudeMach-E
Claude
Quebec Canada
I was, but that actually brings up another question... do we really need an account set up for some retail chargers if we're just swiping/tapping a credit card? I would think if paying "at the pump" so to speak (via credit card swipe/tap), then we wouldn't need an account.
Or do some retail chargers not have credit card readers (and thus require pre-registration)?
I think the later is the right thing , not all suppliers have credit card readers.
timbop
Hmm, the rate is $.43/kwh which is the non-preferred rate. May not mean anything as he may not have Fordpass on that car. It would be nice to find out if you get the regular rate or the member+ rate ($31/kwh) with Fordpass.
ajmartineau
Washington
2021 Mach-E
2.7 kWh/mile on the freeway? ....238 miles.
ajmartineau
Washington
2021 Mach-E
I'm assuming freeway miles from the context of the tweet.
dbsb3233
TimCO
Colorado, USA
Sounds about right, if he's been driving interstate for most of that. 70 MPH speed limit in that area. 238 / 270 range = 12% 70 MPH loss. That's about what I would expect.
Blinkin
James
Zip Code: 48124
16 FoST
If the dash map was showing where he'd been, then that was also a net elevation gain going west and up into Pennsylvania from the east coast like that.
And lots of mountains. Yes, you regain a lot in the downhills and braking but probably only 60-70% so lots of elevation changes will result in at least another 30% range loss even with a net zero elevation change.
