- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Congratulations, I decided to test that just now. The answer is yes, you can heat the battery if you set the cabin temperature to OFF in the departure times setting. If you set a cabin temp, that takes priority and the battery will not be heated in that short time. After figuring that out, I set a departure time for 8:00 at about 7:40. In 20 minutes the battery warmed up from 34ºF to 59ºF, so it is worthwhile to do that. Rate is about 75ºF per hour, do the math to calculate time to 59ºF from current temp. The heating and EVSE will shut off once the pack reaches 59ºF/15ºC. The cabin will be cold though since it will only heat one or the other at a time.I understand just thinking of setting departure time in fordpass, 15 min before I leave , I don't know if it will work ?
Power used for the below was about 2.6 kWh.
