OK, so looks like you'll need BCM, GFM, and APIM (and maybe GWM/TCU) updates to make this work fully? Job 1 probably won't have a frunk button on FordPass until getting these BCM and GFM updates, plus the 3.x updates coming later this year.
@generaltso are you going to post the FORScan as-built changes?
imstriker
Matthew
Indianapolis
Tech
Awesome news, thank you! Sorry for the off-topic, but does anyone know if there is any work going into FORScan to do updates? I'd love FDRS but can't bring myself to buy a subscription.
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
The BCM is, but the GFM is not. It will be interesting to see what happens if they update the BCM without updating the GFM because others that tried that before the GFM was available got a Frunk Fault error in the instrument cluster.
I believe this is why this BCM update was pulled last week. If you just do BCM, you start getting frunk error messages pop on the IPC.
Unfortunately, a source inside Ford has revealed the coding of the software for the OTA queuing. It reads as follows:
If Car_Owner <>JIMRPA, Then Load Update to Queue
Else, Do Not Load Update to Queue, but Display Frunk Button and caption it "Ha, Ha, Ha".
Yeah, I'm sure that's why it was pulled. But it doesn't look like the GFM is installed automatically with the BCM, so some people may still end up getting the error if their dealer installs the BCM as part of a different campaign that doesn't include the GFM.
benk016
Ben
Tulsa, Oklahoma
Yes, its very possible. Another reason I wish an FDRS subscription would let you view TSB data as well. Or at least make FDRS popup when you update a module that this update has a dependency on another module or something. Ford is really making it too easy for dealers and end users to not get it done properly.
The main problem is they post these updates to FDRS about a week before the TSB is published. In that timeframe there are no instructions so stuff can go wrong. They should really release TSBs and corresponding software at exactly the same time.
benk016
Ben
Tulsa, Oklahoma
There is a chance that once the car checks in with the new software it will enable the button in FP.
I'll keep checking in FP to see if it shows up. I actually did have a Frunk button in FP a while back after a BCM update, but it didn't work. Ford later removed it server side, so we know they can flip switches to have things appear and disappear in FP.
Go drive the car and see if it shows up afterwards?
