My range is off
Texas.GT guy
Cypress, TX
2021 E-Mach-1
Real Estate
Brutakus
Vancouver WA
Star White Mach-E Select AWD Comfort/Tech Package
I know I'm late to the party but the reason OP probably thought 300+ mile range is because in Europe (I know OP profile say theyre in US) that's what the MME with extended battery is rated for. I don't fully understand why Europe and US have such different range estimates but I do know the process for testing the range is completely different.
European MME says "
91kWh (98kWh) Extended Range
Drive up to 310 miles on a single charge††
KEY INFORMATION
  • Range: 310 miles††
  • Usable Battery Capacity: 91 kWh"
hybrid2bev
2026 Rally
My GT at home charge shows 100% is 225 miles. I think the manufacture has not allowed the full charge of capacity due to concern about fire. The 80% at home restrictions was achieve by update however there is no way I can get to 270 miles with the up to date software.
I think you're thinking of the Chevy Bolt (that has a software limited capacity until the recall is completed). You can use 100% of the available battery capacity on the Mach-E.
And welcome, recommended reading to get you started:
https://www.macheforum.com/site/threads/53-standard-battery-only-85-miles.12166/post-297977
90% recommended daily charging limit:
https://www.macheforum.com/site/threads/charge-100-but-range-195.12363/post-303284
Real range of the car:
https://www.macheforum.com/site/thr...ulate-how-far-your-mach-e-can-really-go.6104/
Your understanding is incorrect. First, there is no 80% at home restriction.
Second, it's winter. Range is impacted by cold weather.
Finally, the GOM is inaccurate. Dozens of threads on this.
I know I'm late to the party but the reason OP probably thought 300+ mile range is because in Europe that's what the MME with extended battery is rated for. I don't fully understand why Europe and US have such different range estimates but I do know the process for testing the range is completely different.
European MME says " Equipped with an extended-range battery and rear-wheel drive, Mustang Mach‑E has a targeted pure-electric driving range of up to 600 km (more than 370 miles) "
OP is in Atlanta, GA, USA...
dbsb3233
TimCO
Colorado, USA
European MME says "
KEY INFORMATION
Do a Google search on "WLTP vs EPA".
Brutakus
Vancouver WA
Yes I know that...But can you think of any other reason someone would assume something has 300+ mile range when not a single US advertisement said so?
I could, but then the post would be removed because I referenced a quote of George Carlin's...
I make sure my range is off whenever I leave the house!
