MY22 Changes?
EELinneman
Eric
Littleton, CO
Sr. Dir Cloud & Projects
I asked my salesperson about 22 changes and nothing is published yet. He said rumors are a new battery technology along with charging enhancements and probably minor tweaks here and there. I asked if I should cancel my 21 and order a 22. He advised to wait for the official announcement to make an informed decision.
Ford asking people to wait while not providing any useful information!!! Where have we seen this before?
I have it on great authority that the following will be offered in 2022:
PBAAK - instead of phone as a key, phone BOOK as a key will allow the user to call their Ford dealership when they want to drive the car and their spouse took the key.
Enhanced Phone Battery Draining - FordPass will be enhanced to drain your phone's battery even faster.
More to come...
blue92lx
Adam
Ford Fusion
Put the handbrake on first.
Never understand why so many people let a tiny pin hold the weight of their car when there's a entire secondary braking system designed to hold it for that purpose.
Thank you. I've used parking brakes forever because I grew up with manual transmission cars that don't auto lock themselves, it just became habit. But every time I feel a car bounce off the transmission when it's in park I'm just like 'how do you think that's not worse than just hitting P?'. Like is it really that inconvenient to people to just put on the brake?
Deletion of blue, red, and orange from the selectable color palette. Addition of 6 all-new exciting shades of gray.
Mechanical in-frunk release.
T-Rex fart sounds.
prdude
pleasant ridge, MI
engineer
I'm hoping they figure out the brakes.. the electric motors are capable of stopping and holding the car without friction brakes involved. In a Tesla, the friction brakes are only engaged when extra stopping power is needed. The result is MUCH smoother stopping/starting with one pedal driving.
On a similar note, the parking pawl is unneeded. My car always has a pretty harsh rollback when put into park
the rollback is easily fixed by applying the parking brake, before putting into park. Maybe, I'm old school, but this is what I always have done on any car I've owned to avoid stress on the parking pawl
mpshizzle
Utah
Mustang Mach E 4X
Why aren’t parking brakes needed? There are absolutely NO scenarios under which the car would roll without a parking brake? I had a car with a manual transmission once and the parking brake failed. In addition to putting the vehicles in reverse and turning the steering wheel towards the curb, I used a rock as a temporary wheel chock
Mind you I said parking pawl.. not parking brake. I agree. The brake still needs to be there.
I'm just saying a parking pawl is unnecessary as the motor itself can do the same job (and better)
The electric motors are not able to bring the vehicle to a complete stop or hold the car in place. (except for inclines and even then it would create way too much waste heat so the car uses the ABS system to keep the vehicle from rolling). The magnetic field that generates the negative torque to slow down the vehicle breaks down at slow speeds so the friction brakes are blended in for those last few feet.
https://www.forbes.com/wheels/advice/regenerative-braking/
The Tesla system uses the friction brakes to come to a complete stop. Every time. (Unless Full Self Driving is in use, then it uses some other object to collide with to bring the vehicle to a stop.....)
The parking pawl is there for people that refuse or don't know how to use the Parking Brake.
If you are using the parking brake and still are getting a harsh rollback then your parking brake is faulty and needs to be serviced. Tip: Set the parking brake BEFORE you take your foot off the brake pedal. (I don't use 1PD so I am not sure when is the best time to apply the parking brake for those instances.....)???
There is no way the motor can function as a parking brake. Impossible. The contactors are open when parked and turned off so there is no electrical power available to the motor(s). Some sort of mechanical method must be used instead. Parking brake is the best method IMO. The pawl is there for just in case someone forgets to set the parking brake or the system experiences a malfunction.
iankellogg
Ian
Lexus ES 300h, Red Mach E XR AWD
Electrical Engineer
While I agree that its silly to use the motor to come to a complete stop, it is 100% possible and something I do for my profession.
2026 Velocity Blue GT/CS
I don’t believe he wasn’t saying that you couldn’t use an electric motor to bring a motorized vehicle to a stop. I think he was just saying that the Mustang Mach E and the Tesla do not exclusively use their electric motors to come to a stop and remain motionless.
I suspect you could do fancy stuff with the right type of motor and motor control system to emulate “braking” with just an electric motor (maybe try slowing most of the way down, then reversing the motor? Or having a huge motor relative to the payload? I’m not smart enough)
Yes, but the fact remains that in order for an electromagnet to hold, power needs to be applied. An electric motor is more or less a series of electromagnets timed to create motion. Apply the power in the correct fashion and you have lack of motion. To hold it still, it would require power, which would generate heat. Not an efficient way to “park” the vehicle for hours on end.
Agreed.
The way it was explained to me is that it is possible but the energy required exceeds the energy gained at slow speeds so it's best to blend in the friction brakes.
Holding the vehicle in place while parked. Not possible unless you want to provide constant power to the motor(s).
mpshizzle
Utah
Mustang Mach E 4X
Well I stand corrected. I assumed that a permanent magnet motor (by virtue of the fact that they are permanent magnets) could not be turned without power.
Well, in any case, if Tesla does use the friction brakes (assuming no fsd, of course ?) then Ford needs to take a page out of their book. Slow speed starts and stops are indeed very much smoother with one pedal driving on a Tesla.
As far as parking brakes go... I personally am gunshy about them from previous vehicles. I've had problems with warped rotors that came from me engaging the parking brake with hot brakes... Granted. That was a poorly built vehicle from years ago, but my subconscious won't let it go ?
bp99
22 MME eAWD, 21 MME CA Route 1 (sold)
New battery technology? That seems like a longshot...
Perhaps just a switch to the SK batteries being used in the Lightning. They're reportedly similar to the LG cells, so not really a technology change, but is probably better logistically with the supply chain and cost volume-wise.
