OTA 1.7.1 Stuck, anyone else have issue updating?
Mike G
N. AL, USA
'23 Mach-E GT-PE, '22 F-150 Lightning
I know that Ford has released updated procedures to clarify to the techs some issues they need to be aware of while performing certain updates. But I have heard nothing about updates being "retracted" except the F-150 Trailer module update, and I think that one has been re-released.
See attached...
Ford Mustang Mach-E OTA 1.7.1 Stuck, anyone else have issue updating? Updated FSAs
Mach-e4x
Oneonta, NY USA
2021 Mustang Mach-e 4x, 2016 Mazda CX5
I'll be dropping my car off tomorrow, 10/20 build date, for the stuck 1.7.1 update. TSB 22-2117, TSB-22-2150. I mentioned that the FDRS software must be updated before they start. They said they are "well aware of that." Maybe my car is on the way to getting Blue Cruise installed and working.
slambertr
Scott
Pennsylvania
Mach E Premium
It's alive! My dealer successfully un-stuck my MME from 1.7.1 purgatory. They previously completed the windshield/panoramic roof recall work and replaced the faulty shaft/axle. I'd recommend New Holland Ford to anyone in the Central Pennsylvania area. And I greatly thank everyone on this thread for their advice and info. Good luck to all!
samlaw13
RWD MME Selext
Ford just told me that I have to take the car back to the dealer because it hasn’t done an OTA update since I picked it up. I asked why no OTA deployments have happened and she couldn’t give me a reason other than there must be something wrong with what the dealership did because on their end it’s showing that the updates failed last month and then was cancelled. Now I’m stuck at 1.7.1 and she told me until it’s fixed, no OTA for me
Mach-e4x
Oneonta, NY USA
What Sync version do you have now?
Do you have notes?
Can you turn updates on and set a time?
MrRossKeys
San Jose, CA
Mustang Mach E First Edition
Just dropped my car off today to get it across the finish line. 30 days ago I had all modules updated via FDRS except the APIM which failed using FDRS. The service department applied the windshield recall and then held my car for a week without telling me they needed to order adaptors.
So it's in today for round 4 of attempted updates since December to get it unstuck (no OTA's ever). I got a Polestar on loaner so thankfully I won't need to buy gas in the meantime. Technician is estimating 2-3 days turnaround.
Mike G
N. AL, USA
Well you got at least one OTA.....the one that you got stuck on!
I know it's not much of a consolation though.... :rolleyes:
Jeffvisor
Harrisburg, PA
Ford Mustang Mach-e
My car is on "recall" which wasn't resolved and now they are doing the APIM (I assume that - they said Ford was sending them a part needed to get updates going). BECM and HVBJB have been done. Definitely need to keep at them. Told them 3-4 months ago the APIM needed replacing.
Looked to change my dealer and called another and they wanted to do my windscreen so my dealer at least seems the most progressive around even if mine was the first one they've done.
I feel I am in the same boat stuck on 1.7.1 they had my car in service for all total 2 months I only had the car less than 10 months so 20% of the time its been at the dealer for service I still don't know they fixed it. I bet I need a new APIM too. Frustrating!
Kneebeard
Toronto, Canada
Mach-E AWD Select
If you give me your VIN I'll check to see what updates you may have pending.
Any chance you might be able to check my VIN?
I just took my car into the dealer today, they said they fixed it. I can see my Sync version again and toggle the Auto Updates again, but not seeing Notes or Tic Tac Toe, and my Sync version is still the same before it got stuck on 1.7.1
Mike G
N. AL, USA
Sure, send it.
AllenXS
Allen
Richmond, BC, Canada
Premium Blue ER AWD
They sent the apim I believe but wanted to try an update first. They’ve started the second try. I bet they do the apim tomorrow!
finally got a rental car. At least ford Canada are monitoring it all the way.
AllenXS
Allen
Premium Blue ER AWD
Two days in and finally at 1.71 it seems. More updates tomorrow and I get to see if it’s really unstuck. Be nice if it’s all the way to blue land.
kimbroe1981
Kimmie
Norman, OK
2021 Mach E
I bought my car June 21. Had it for almost a whole year and ZERO OTA for me. The dealership has replaced my APIM. That was a couple of months ago. I seem to have a newer version since then. I believe maybe 1.7, but not sure really how to check.
I am now able to schedule reoccurring updates, but they always fail.
I have the fordpass widget on my phone. Shows its been trying to do the Ford Power-Up 2.1, but every time it tries, it fails.
I will be picking her up today from the dealer. I had the window recalls done, the 3 days it was in they were not able to force any updates either.
Dealership has the gateway module on order. Maybe that will fix it?!
Anyone have any ideas to try or have my dealership try?
CHeil402
King of Prussia, PA
2017 Audi A4, 2021 MME
Electrical Engineer
Do you have any of the "apps" on your car such as Notes or Blocks? There isn't really an easy way to check which PowerUp you have as it's not directly tied to a software version so much as an assortment of many smaller updates. You can mostly just check against "features" that were added in the list against what's on your car.
https://en.wikipedia.org/wiki/Ford_Power-Up_Version_History
I had my software uploaded at the dealer so I know I'm current but the update widget shows that I'm failed at 2.7.1 (which isn't true since I had all the updates manually installed at a dealer).
kimbroe1981
Kimmie
Norman, OK
2021 Mach E
I have notes. No blocks.
I would be happy if the dealership could get the updates to install there. But those haven't worked either.
I will take a look at the wikipedia page. Thnx.
Just looked at the wikipedia page. Looks like a parts of a few updates. I have notes and the light/horn button on my ford pass, but none of the other apps.
