Poll on charging current 10-3kw
Set the charger to what?
  • Total voters
Dylancch
Dylan
Swift current
Mach e
Construction
I bought a 10kw charger today and hooked it up to the car. I'm getting a steady 9kw. So I'm not sure if the charger is limiting that or the car. Anyways do you think it's harmful to maxout the charger for longterm use or should I turn down the charger to a 7.5kw charger so the car and the chargers only running at 80% instead of 100%
Ford Mustang Mach-E Poll on charging current 10-3kw Screenshot_20210822-170256
I don't believe the on board charger is user configurable. ??
TheCats
Y5Z
Are you hooked up to a 208V (one leg of 3 phase 240V) or a 240V system?
The on-board charger is rated at 10.5 kW (*), which appears to be 240V @ 44 amps. If you supply 208V, the current is still limited to 44 amps. 208V @ 44A is 9.152 kW.
* European destination cars with a CCS2 onboard charger appears to be rated at 11 kW. CCS2 has a three phase option, so the onboard charger is likely very different.
Dylancch
Dylancch
Dylan
Swift current
Mach e
Construction
240.v
kltye
IB MME Premium RWD
I would charge the battery as slowly as possible for your daily needs, and then add maybe 15% to that number for emergency use. No reason to keep the state of charge high if you don't need it.
You've previously said you have 40A service, if that's the case YOU ARE OVERLOADING your circuit charging at 9.6kW. You need to set it to 32A/7.6kW MAX on 40A circuits (80% rule). Your charge rate is limited by your circuit size and must be set correctly to avoid an electrical fire.
Also you can't just swap the breaker out for a bigger one. Breaker has to match the wire size.
Dylancch
Dylancch
Dylan
Swift current
Mach e
Construction
Charging from a wall outlet(240volt) is extremely low current at 10kw. I bet it's a .1c rating you think your putting in that's only 28 amps at 360ish volts dc on the battery. A 1.c rating would be at a fast charger putting in around 80,000watts
Dylancch
Dylancch
Dylan
Swift current
Mach e
Construction
Breaker was replaced by an electrician and he oversized the wire previously because he new I wanted a 40amp evse
Dylancch
Dylancch
Dylan
Swift current
Mach e
Construction
And FYI 208v is 2 legs of a star configuration 1 leg to neutral is 120v. Or unless your referring to 1 leg of delta configuration wich I believe is 277v
