Neil4Real
- Jul 8, 2021
- Southern California
- Mach-E GT Performance Edition - Shadow Black
Well, it seems to be similar power limiting, maybe it reduces slightly faster and allows a bit more power up front for slightly longer, but it is still there if you're slamming it.Well I think it's pretty obvious that Ford implemented a strategy of the GT's having to derate their power to prevent issues such as the ones afflicting the HVBJBs.
I'm not sure there was a master plan here, but I would put $1 on there being less power limiting that I've seen today. It seems like the power limitation timing is shorter. I think there might be a little less derating going on with the extra spicy parts and software, but I think someone would have to hammer two identical cars except for the robust box, and compare.
You almost need a camera just taking video of the power meter (the jail bars are sooo small) to compare when they go away after giving it the beans.
All of the below was done in Whisper.
I did about 5 or 6 WOTs on the freeway today, first one I hit 100 before I was hard power walled, before once I'd hit high 80's/low 90's it was a crawl to 100. I then backed off to about 65 and slammed it again and the power wall was hit quicker and quicker as I repeated it. After the 5 or 6 WOTs, I was left with about 50% power, I set cruise control to 65 and the 50% remained for about a full minute. It then reduced to 33% reduction, then just 4 bars, then 2, then 0. It FULLY cleared to 0 bars after roughly 5 minutes of driving. I was at 90% SoC when I did my "testing."
Thankfully I hit the 50% limit when I did as I saw a motorcycle cop right around the bend when I slowed into 65 MPH on cruise control!
