Puddle Lights
My mirrors unfold when I press unlock or approach car with wife's phone as a key.
What if you simply walk up to the car with the fob? Don't press unlock on the fob, just walk up to the car while mirrors are folded and the car is locked.
Major
Major
Houston
Mustang Grabber Blue First Edition
I'm having the same experience as most of you. It just haphazardly works when it chooses to. I do carry my linked phone at the same time as my fob. The fob is in my pocket and the phone is in a case on my belt.
Regularmache
Stephen
US
Purchasing
OMGosh! Actually saw the Puddle/courtesy/LochNess, light today! First time in 5 days of ownership. We were headed out to church this morning, garage door shut, and Low and Behold; Pony on the ground, it stayed lit long enough for me to hold it in my hand for mere moment's when just like that it was gone! So I know they are there, and the lamps are connected, the car can show the little pony, but I have know idea what scenario it will appear. MY 18 GT, it came on with the unlock, or stopping the car and getting out until it was locked then poof! The Electric Pony ? seems to have different parameters.
Jimmy2
Jimmy
Wilmington NC
I have not taken delivery yet, but I plan to carry the FOB at all times too. I'll spring for the additional FOB as well for the wife.
Dmhccs
Dani
PA
2021 Volvo XC90 recharge, 2021 Mach e GTPE
Business owner
Ford only provides one FOB?? I’ve never heard of that. I’m sure my husband will want to drive the car!
Regularmache
Stephen
US
Purchasing
Pony posed for pic! Been seeing the puddle light more consistently!
Ford Mustang Mach-E Puddle Lights IMG_20210310_181036
MailGuy
Washington
Bolt Premier, Mini Cooper SE, Mustang Mach E FE
Before i configured PaaK, the car would consistently turn on the greet lights, puddle lamps and door rings (push buttons) when i was only using the fob. After PaaK enabled on two phones, the car rarely greets me, even with using the fob. PaaK has refused to unlock multiple times and refused to walk away lock at least once. I am hoping an OTA will resolve this. I’m honestly ready to turn off PaaK and get a second fob instead. We keep our phones so close to the car that one of them always shows connected, even if the Ford App is not running. Really want a consistent experience, especially the lock part.
Update:
Maybe I'm being too harsh on PaaK. I have some limited evidence that the greet/pony experience is dependent upon how you approach the car.
It occurred to me after posting this that I had changed my behavior with the car. Lately I've been backing the car into the garage whereas for the first week I pulled into the garage head on. When the car is backed in, I approach the car from the right rear quarter panel and am further than 19' from the front left quarter panel. I generally walk behind the car and along the driver side to open it. Result: No greet/no ponies/no rings lit on the door, PaaK unreliable, Fob reliable for unlocking but without a greet experience.
So I did an experiment. I disabled Bluetooth on all devices, pulled the car head on into the garage and used only the fob. I approached the car, shut the door, turned it on, waited, turned it off, opened the driver door and exited. Result: The car greets me every time I return and the ponies light up on the floor and the door rings light. The car also locks when I go out of range. I repeated this sequence many times.
I then enabled Bluetooth on one of my phones, opened up Ford Pass and left it in the foreground (seems to be a requirement that the app is running in the foreground on my iPhone for reliability). Using the same sequence as above, the car greets me, the rings and ponies light up every time using PaaK with the fob out of range.
Feeling empowered with my abilities. I then tried alternating start/stop cycles using the fob for both and then PaaK for both. Result: Everything worked as advertised.
So maybe it comes down to which sensors trigger first and not confusing the car with too many active keys. I've found that PaaK has longer range before it disconnects so I have to kill the app on the phone for it to disconnect. When I'm at home and the phone is sitting on the kitchen counter it's close enough for the car to detect it, but not trigger greet experience. Not exactly the seamless experience I was hoping for. Thus, I'm still leaning to just get a second Fob and truly use PaaK as a backup mechanism.
GregD
Auburn, WA
2021 Mach-E FE, Grabber Blue
He may WANT to drive the MME, but will you let him? In my two days with my FE (ordered via Mach Drop), I’ve used my iPhone as key a couple of times. There was a slight glitch the second time, requiring closing/reopening the FordPass app before it would start.
The dealer says that using the door code will work not only for entry, but also for starting the MME via the screen. I have not tried that yet, but that would make three ways to drive the car, only one needing the key fob.
Dmhccs
Dani
PA
Business owner
Yes, after he has listened to me talk about the MME for months, I must let him drive it! I’m too anxious to rely on the iPhone given some of the issues that should like yours. Maybe I will just order a second FOB but I have to get the car first and that could be awhile!
shutterbug
Joseph
AZ
Based on what I saw in the manual, you can set up a backup start code. It's not the same as the door key.
GregD
Auburn, WA
Ah, now that you say that, it reminds me that the dealer may have mentioned a different code for a start code. He did talk about two different codes, but I was not the best student at that point. I just wanted to go!
VegStang
Leo
Silicon Valley
Volvo C40 Recharge, 2023 MME
I dunno, the car would greet me with the puddle lights and door buttons every time the first night, had to show the whole family of course, but now after setting up the phones I get nothing. It seemed to be working earlier today when the sun was out, but now that it matters and it's below 50f (don't really think it matters, but it's a change) I get a dead asleep car, push the button to wake it up, then push again to open door. This is with fob and phone, phone only or fob only, walk around entire car from front or back.
Left the car for a few minutes earlier today, turning off motion sensors as I left as my son was in the car, alarm goes off when he moves. :rolleyes: Is that the back seat occupant reminder?
VegStang
Leo
Silicon Valley
Ah, hell no. The #notamustang crowd shall not prevail. :eek:
I heard they were changing the visual to a ford symbol on the first OTA.
Mirak
Kansas
I agree with the suspicion that the inconsistency of the puddle lamps is caused by spotty PAAK or by some confusion between PAAK and fob.
My lamps work often enough that I’m not gonna drive myself nuts trying to nail this down. Hopefully some of the smarter folks at Ford can fix this with improvements to PAAK. For now, I’m going to leave PAAK enabled and keep carrying my fob.
