Range Keeps Increasing Past 211 Miles w/ 100% Charge
vinnym777
Vinny
2021 Mustang Mach E4 Select
Hey All!
This is my first post so be gentle. Just have my Mach E for a month and its gets better as I drive it.
I have a Select AWD with the standard battery and I am noticing that the range has increased over this first month. It started at 211, then 220's, then 230's, and now after finishing the last charge it says 245.
I don't know if this is the true range or this is an issue I should be concerned about.
Does anyone have any insight on this?
Thanks,
Vinny
DRob1260
Drew
IL
Mustang Mach-E Premium, infinite blue
I believe it’s probably adjusting its range estimate based on your driving habits, weather, etc. Pretty cool that you’re getting estimates well beyond 211. The estimates are supposedly pretty conservative, too.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
praxiscat
Christine
DC
Mustang Mach-E, Tesla Model 3
You are not doing anything wrong. Range is algorithmically determined based on how you drive and other factors. Ford did a really good job on this. They maybe even making the motors more efficient.
ESilver
Sterling
Idaho Falls
Titan, Sequioa, Yukon, Rogue
Business
85% of my miles are going 85 mph on the freeway. The other 15% are me gunning 0-60 sprints between stop signs each mile to my house from the freeway.
I have premium AWD extended and my range is typically showing 250-270.
I would guess you are more reasonable in your driving habits.
vinnym777
Vinny
Thanks
Hey All!
Thanks,
Vinny
It's learning your driving style and adjusting the guess-o-meter and navigation estimates accordingly. It happens for everyone after delivery.
Garbone
Gary
Loafer
On my SR RWD I have seen 300 once or twice. A few trips down the highway at speed will push it back towards reality.
AZBill
The key is to not trust this number when you take a highway trip. Since you have a standard range AWD with combined EPA of 211, the highway EPA is less than that. Taking a highway trip you need to be ready to recharge at about 150 miles to have some margin, because your real range will likely be more like 200. If you drive at higher speeds, like the 75mph speed limits out west, you will take a big hit on range. Same if you are driving up a mountain.
Real world example, with my Bolt. Combined EPA 238, highway EPA 218, actual usable range driving at 75mph through the flat desert in AZ, 190 (based on real experience). I once did a trip between Phoenix and Tucson at 75mph with a 30 mph headwind and range was only 170.
jrstinkfish
Scott
Memphis, TN
2021 Mach-E Premium RWD SR Infinite Blue
It's taken my Mach-E about a month and a half from purchase to now to start raising my GoM estimates. For the longest time I could not get above 200, now it charges to 100% and hovers between 210-213. Not the 230 my SR was estimated to get, but then again, I've made two 1000-mile round trip road trips in that time and the high speeds may be skewing it a bit. We don't return to the office until September, so once I go back to daily driving, maybe it will trend upward.
Trede
Trede
Kent, WA
2021 Grabber Blue FE
Do not charge to 100% on a regular basis if you want to get the most life out of your battery. There are tons of resources online that can explain why, but the bottom line is you want your battery to spend as much time between ~60-80% as possible. Owner's manual says limit charge to 90% (which is about 80% of the actual battery because of reserve) for day-to-day type use/charging.
(I set my limit to 85% just to be extra nice to the battery. This is my data after almost 3800 miles)
Ford Mustang Mach-E Range Keeps Increasing Past 211 Miles w/ 100% Charge Screenshot_20210702-073017_FordPass
Ford Mustang Mach-E Range Keeps Increasing Past 211 Miles w/ 100% Charge 20210701_072742
KennyCaphill
Kenny
Seattle
Mach E Premium Edition AWD Standard Range
Insurance
Looking at all these posts makes me jealous. I charge my Premium AWD standard battery to 90% and get about 175 miles on that. Apparently I drive like a jerk!
machrapidred
san antonio
Mach E select standard range awd
Is there a way to limit your charge or change your charge target without a smart charger?
dw0095
D
Upstate NY
MME Premium
Question about wear and tear on battery while consistently charging to 100%
What kind of damage to the battery are we talking about? Will we lose cells or will it just discharge at a faster rate?
Will ford deny claims on covered warranty parts if it shows consistent 100% charging?
I have the standard battery which is obviously the shortest range option so I have charged it to 100% twice since owning (at 265 miles on the odometer so far). I don't plan on keeping this car for more then 3 to 5 years tops.
If I follow the 60-90% charge target, am I only preserving battery life for the secondary buyer?
Just trying to learn if this will start the degradation of the battery right away.
Nklem
Norm
Coast of Maine
Subaru Solterra
Mechanical Engineer
My AWD SR range and it’s 100% able to do it….. I accidentally charged to 100% at a new charger.
Ford Mustang Mach-E Range Keeps Increasing Past 211 Miles w/ 100% Charge 8AC54F4F-AB9C-429D-8A86-948FBC0237A4
