nashbrydges
Sylvain
ON, Canada
2022 Mustang Mach-E GT performance
For anyone who runs a Home Assistant instance, I'm pretty new to it but recently got my FordPass integration working well and includes an insane amount of data that you can monitor over time as well as build automations like alerts if your 12V SoC drops below X%, notify me if I've left my doors unlocked or windows down and it's after 6PM, notify me if tire pressure drops below YPSI...etc. Use this data to build yourself a dashboard with all of this cool data.
SteveMach-ee
SteveMach-ee
Mass
2021 MME Select AWD, 2023 Ariya Venture+
This does not seem to work anymore. Apparently, have changed how the dashboard works. If the reason for the change for them was just seeing this or a similar post and preventing us from accessing that data, I have no words for Ford...
Still works the same as i documented on Chrome. Does "status?..." not show up? Perhaps there was a temporary Ford server issue.
nashbrydges
Sylvain
ON, Canada
I just finished (er...work in progress) my mach-e Home Assistant info card and sharing it here in case anyone is interested. I'm 30 days into having HA and so far can't believe I've not had this in my life before.
I've manually changed the state of the front left tire so you can see what happens when there are no issues with tire pressure (the icon goes away). The other tires have the warning because I don't have TPMS installed on my winter wheels...maybe next year.
When charging is active, there are 3 lines that appear at top middle to indicate the charging power, volts and amps but those remain hidden unless charging in happening.
I've included a bar graph for SoC for both traction and LVB batteries and included the LVB voltage as well.
I haven't included window status and may do this at a later time.
Ford Mustang Mach-E Remotely Accessing LV Battery Voltage from Ford.com with Chrome Browser Screenshot 2025-02-04 at 3.37.02 PM
SteveMach-ee
SteveMach-ee
Mass
Nice! Thanks, definitely interested. Suggest you start a new thread on it.
Old_Norm
Columbus Ohio
Can you tell us which integration you used?
nashbrydges
Sylvain
ON, Canada
I'm running on the latest HAOS v2025.2.4 on a virtual machine and the Fordpass integration is v1.7. You need to use v1.7. The earlier versions don't work at all.
Follow this for setting up the integration.
https://github.com/itchannel/fordpass-ha/tree/1.70
Follow these instructions to obtain the necessary tokens.
https://github.com/itchannel/fordpass-ha/wiki/Obtaining-Tokens-(As-of-25-05-2024)
It's a pain in the ass to get but if you follow the instructions to the letter, it will work.
Old_Norm
Columbus Ohio
Thank you.
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
For the users that are setting up home assistant and the FordPass integration, make sure you turn the polling down to something like 600 seconds. If you hit the API more than 200 times in a 24 hour period, your account will get locked out.
nashbrydges
Sylvain
ON, Canada
Good reminder. By default, the integration is set to 900 seconds but good to check and confirm.
randomvoice
Mustang Mach E GT
Does this method still work? Seems like the dashboard on Ford is redesigned.
SteveMach-ee
SteveMach-ee
Mass
LVB voltage access through the developer toolbox still works. Just tried it.
randomvoice
Mustang Mach E GT
I tried with Chrome and no luck. I guess it is taken out? I can't seem to find anything under XHR > Name with 'status'
randomvoice
Mustang Mach E GT
Disregard the above. Tried it in incognito and it worked. It shows 13.45 though. Is that normal?
