That thread says Level 3, not at home, Level 2. Does the actual TSB cover L2 as well?
Since Level 3 isn’t a real thing, they may or may not have meant DCFC. But it says it reduces the noise when charging at 10.5kW and above, which you can certainly hit with Level 2.
ericNdfw
ericNdfw
Eric
DFW, TX
ericsmalling.com
`21 MME Prem 4X w/GTPE wheels,`22 Hyundai Palisade
Solutions Architect (software)
Cool! I'll be looking into that ASAP then! Thanks for sharing.
Guy
Guy
Canada
Premium AWD Long Range
That's the way it is. Remember the first flat, Plasma TV's? They got bigger, better and cheaper every year, and the the LCD's came. Why would it be different with EV's?
DaveHsr
Mach-E on order
manager
I think the concerns are leaks along with too many hoses and connectors. The Ford engineers was great but indicated the rear engine and cooling systems require re-engineering and they needed to just something out to market.
We are torn because we want a EV but reliability is important to us. We have already accepted the phone as a key sucks and plan on getting an additional key fob.
Yes, I would recommend a second key fob. I'll probably go back to get another. The cooling system may have many hoses, but it does seem effective. The cabin cooling is excellent, and based on my limited experience you might want to confirm that in other EVs.
barryezl
Barry
St. Petersburg, FL
Mach-E Premium SR RWD
What is it that Sandy doesn't like about the rear motor? She obviously knew what he was referring to but I didn't catch it. Anyone know?
TRP
Mach E P4x, Ford F150
He doesn't like the oil squirters and the redundancy Ford used. He preferred the front motor with the coolant pathway machined into the housing
eStang
Larry
2021 Mustang Mach-E FE, 2021 Mustang Mach-E GT
software salesperson
He also preferred the press fit to hold the stator in the housing approach of the front, instead of the long thru bolts on the back... Because, Fasteners.
barryezl
Barry
St. Petersburg, FL
Welp, I guess I'll trust the Ford engineers did a good enough job and if not it should be covered by warranty.
EELinneman
Eric
Littleton, CO
Sr. Dir Cloud & Projects
Chiefsfan
William
chesterfield, mo
Lexus GS350
What model year switch to android from sync? I know it was mentioned as 2023. Was the introduction year or model year(which would be MY24)?
