hetgeleteken
Martijn
Utrecht, NL
VW Golf Estate, Ford Mustang Mach-E AWD ER Lucid Red Tech+ reserved
Can someone perform these steps and PM me the info? (Only need one of 2 for comparison)
Overwrite your current script with this.
https://gist.githubusercontent.com/...ab11263667cf1d878ff84d62/Fordpass%20Widget.js
Open the Scriptable app and tap the ... on the Fordpass Widget.
Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) {filename}
Tap the blue box with a number next to the play button and then tap the play button.
When the menu shows just press done.
Tap the ... to the right of Logs windows and share all of the text with me here...
This will be a large chunk of text!
I sent you a PM with log details
hetgeleteken
Martijn
Utrecht, NL
By the way I do often get a "Script not found" message in the widget. If I click on it I sends me to the Scriptable app, and then it shows up. It almost feels like I have to run it again in order to become 'active' again.
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
New Release v1.1.1:
  • Initial support of Electric Vehicles (battery charge, and range)
  • Added screen size detection to adjust the font size on iPhones with smaller displays. (Will be used later to fine-tune the padding of the widget).
  • Added a version check to show you on the widget and main menu if there is a new version available.
  • Low Voltage Battery Text now shows up as a red when it is low.
  • Status Text is displayed at the bottom of the widget. When a vehicle is in deep sleep mode, the firmware update is in progress, or the vehicle is in a low voltage battery state, the status text will be displayed.
  • Fixed bug in using metric and defining psi tire pressure.
  • Tweak the padding of the widget to make it more consistent.
  • Fixed tire pressure font so it matches the rest of the widget.
Script Link: https://raw.githubusercontent.com/tonesto7/fordpass-scriptable/main/Fordpass Widget.js
hetgeleteken
Martijn
Utrecht, NL
New Release v1.1.1:
Awesome, will try it out immediately!
Update: Done, works like a charm, no error messages and now see battery charge leve, range and charger status. Great stuff!!!!!
COACH CHRIS
C
NJ
Mustang Mach-E AWD Select
Can confirm, works great! (As it were, I thought my car was charging so I was surprised to see 80% but alas, it is not plugged in! So all good.)
Ford Mustang Mach-E ? Scriptable FordPass Widget (iOS, iPad, MacOS) 6F924A15-D14A-422B-88D5-4758CC30E174
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
It's interesting that the API is showing your 12V battery as low.
COACH CHRIS
C
NJ
Maybe the thinking was “anything other than 12V = not good = “low” so folks will take a look at it”? But yeah no idea.
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
I might need to remove the color change and alert on EV's if it becomes an issue
GoGoGadgetMachE
There is a limit to what Kohler, Google, Amazon, Facebook, and others need to know. Is there no last bastion of privacy left? ?
many companies sh*t all over your privacy so why not expect them to not give a sh*t about the privacy of your sh*tting?
Marcel
The Netherlands
Woodworker
Is it possible to make instructions for dummies? I installed scriptable and need to copy paste the code in the link?
GoGoGadgetMachE
I apologize, that was a sh*tty response.
jesc
Juan
Spain
Mach E
New Release v1.1.1:
Really good work!!! Works Great!!
ZuleMME
Zule
Denver, CO
21' Job1 P4X MME, 22' MYP
Implementation Engineer
Now it just needs a better way to update. I don't know about the rest of you but trying to copy all text on a iphone takes forever to drag all the way down that script file.
