737flyer
Richard
Redington Beach, Fl
2025 Mache Premium, 2024 BMW IX50
Retired Airline Pilot
I really liked this app. Last night I got locked out for using my utility company’s program, charging during off peak hours.
I will not connect any other apps through Ford pass again.
Be careful
BillPitman
Pa.
Ford Escape, ‘21 J2 Mach e, 2024 Maverick Hybrid
Are we ever again, going to be able to use this great script, safely ?! Bill P
tonesto7
tonesto7
Anthony
Ann Arbor, Michigan
2021 F150
Software Developer/System Admin
Yes. There is an official API in the works. I will hopefully have beta access soon. Then I can get the widget working. Once the API is released, it will require you to create your own account to get the credentials to get your tokens legitimately. I will provide an announcement once I have more info and details.
acosmichippo
'22 Select Dark Matter Gray
that makes it clear why they started cracking down on sharing credentials last year.
mikeinet
New York
Standard AWD Tech/Comfort
Cyber Security, First Responder
But in standard ford ways… stop behavior before you can do it properly… new api… SOON!
BillPitman
Pa.
Thanks for this info Anthony! Bill P
Mauser
Canada
'22 Mach-e GT-PE Space White
Just a quick question: Is this still active? I've been updating the widget, but it hasn't been able to pull any info on my car in about 8 months. Running the Tool keeps failing.
Deleted member 16048
Guest
Based off the last message apparently someone was working on a way, but I know the Ford TOS has not changed. So anything third party is NOT legitimate or approved so you risk losing FordPass access all together.
Jmmanley
Fort Collins, CO
2022 Mustang MachE
Airline Pilot
YEP! I had HomeBridge installed to allow FordPass access. My FP account stopped responding. I received a contact request from Ford and was told I was in violation of the TOS. I needed to disconnect my third party program from Ford Pass, and if I did it again, it was a LIFETIME ban from Ford Pass! I wasn’t impressed with how Ford handled that but it’s their show. It’s too bad because Ford Pass is mediocre at best…they would truly benefit if they gave the public the ability to innovate. .
e-pony
SoCal
Premium AWD Extended Star White
FordPass Scriptable Widget v2022.02.18.0
Description:
Many months ago I found a FordPass widget while searching for some Ford pass API stuff.
I've completely refactored the entire script and turned it into an alternative control to FordPass.
Feature Walkthrough Video:
What's New in V2:
  • New Widget Designs
  • Define widget types in widget settings as a parameter (this allows you to have multiple versions of the same widget. If you don't define a color mode it will use the system dark mode setting.
    • detailed
    • detailedDark
    • detailedLight
    • simple
    • simpleDark
    • simpleLight
  • Quick action buttons on some of the widgets.
  • Modified the fuel/battery to embed the icon in the bar itself.
  • New dashboard app that opens in scriptable for info and controls
  • Push notifications for the following:
    • Widget updates
    • Deep Sleep Mode
    • Low 12V Battery (off by default)
    • Firmware Updates
  • Lots and lots of bug fixes.
Download and Instructions:
https://github.com/tonesto7/fordpass-scriptable
Ford Widget Tool Installer (tonesto7.github.io)
Updating from v1:
Please install the latest widget tool
Latest Release Announcement:
Reporting Issues and Feature Requests:
Please open up issues or feature requests here https://github.com/tonesto7/fordpass-scriptable/issues
If you are a coder yourself please submit pull requests and I will gladly merge them if they make sense.
Giving Thanks:
Thanks again to dschablowsky for all his work on the original script which gave me the ambition to make this beast of a widget.
Please dear Jesus, after experiencing the crappy FordPass V5, let this new widget work!!!
This is a two year old thread. Widgets such as these can end up getting your account locked as well.
Dynamo
Vlad
Capital
Ford Mustang Mach-E GT PE 2023 & Lincoln Corsair Reserve 2.3 AWD 2020
Hello, did you receive beta access, or is it still in development? Because on the Ford Dev site, registration is unavailable.
*At this time, we are no longer accepting sign-ups for the FordConnect API*
