Sensitive cruise control button
JJR
James
Colorado
2022 Mach-e Premium
Artist
This has happened to me a few times now. I’m accidentally turning on the cruise control by touching the button with the heel of my left hand. It seems that the button is very sensitive and the speed selection does not reset to zero when turned off. A quick tap of the brake shuts it off but it’s a bit annoying.
Anyone else have this happen?
MarkP213
Mach E 4X Premium, Infinite Blue
Yes! All the time. I have a bad habit of resting my hand in the same place. And it’s scary with one pedal on, pulling up behind someone at a stoplight and having the car car suddenly lunge forward on its own. Then I look down, and cruse control is set when it wasn’t before. ?‍♂ I’m very aware now.
Never in over two years with the car. It must be the way you are used to holding the wheel. Time to learn a new habit.
hbirring01
Baltimore, MD
2021 Ford Mustang Mach-E, 2025 Rivian R1s, 2021 Tesla Model 3
Happened to me several times as well. One was in a parking lot which was really dangerous. Seems like it should be hold the button for 2 seconds or something to turn on bc/cc.
JJR
James
Colorado
2022 Mach-e Premium
Artist
Just had a chat with Ford.
Swapping out the button with one that requires more pressure to activate is one solution.
This.
The old 10-2 or even 9-3 are no longer considered the safest hand placement due to the airbag placement. 8 and 4 are better to avoid injury than 10-2 and will have the added benefit of not engaging cruise control or BC accidentally.
JJR
James
Colorado
2022 Mach-e Premium
Artist
There’s no need to “press” it. Running the heel of your hand over it is all that it takes.
JJR
James
Colorado
2022 Mach-e Premium
Artist
This.
Unfortunately there are times when I need to move my hands around the wheel like when I’m making a turn. Just touching the button seems to activate it.
Metasystech
Todd`
South Florida
2001 Ford Lighting 1996 Chevy Impala SS 2022 Ford
Self Employed
This happened several times to me and I thought it was turning on cruise control by itself. It is really easy to touch it and off the vehicle goes. I'm not sure if it is placement or sensitivity but it's not good.
Stormy
Upstate NY
2022 Mach E SEL
I had this happen when driving down a short, narrow street and it was set to 20 by accident. I use 1 pedal and had to jam on the brakes at the stop sign. Frightening.
Ford Mustang Mach-E Sensitive cruise control button macheforum app copy
JJR
James
Colorado
2022 Mach-e Premium
Artist
Just spoke with my neighbor who mentioned that his Honda requires a 2 second press to open the rear hatch.
I’m changing my vote to your idea of a 2 second press.
Should be a simple software upgrade.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
It is of course possible that your button is extra sensitive and that changing it might make sense, especially if you can convince Ford to do it under warranty.
I’ve done it a couple times in my 26 months of ownership. When it happens, I realize it’s because of the way I’m handling the wheel. I don’t consider it a big deal, I just need to pay attention to what I’m doing.
Tom L
Tom
Chippewa Falls, WI
2018 Honda Clarity
JJR, How do I do this swap? Is there a Ford part?
