Steve92110
- Steve
- Sep 25, 2022
- Uk
- AWD Mach E
I thought that’s what the “L” selection was for ?
I'm just over the river in Jersey, and I've never put snow tires on any of my 4 mustangs over 26 years of driving. With that said, 1PD seems to be optimized for dry conditions - especially in the more aggressive drive modes. In my prior stick shift mustangs I got pretty good at feathering the clutch and/or downshifting just right to slow down without sliding or having to hit the brake, but I don't think the go pedal on the Mach-E has enough feel to accomplish the same effect in 1PD. So, I just avoid driving in slippery conditions or turn off 1PD when I have to drive in them.Nope. I’ve always thought about getting a set but, with over 750 days without snow (until now), it seemed pointless. Besides, I don’t have a place to store a second set of tires.
No - the "L" puts it in the most aggressive regen/1PD mode, which is actually more likely to cause it to lose grip in snow/iceI thought that’s what the “L” selection was for ?
Oh, this is helpful. I didn’t know the traction control was tuned to allow rear-end slide. That’s why it feels a bit like my Miata felt in the snow.My car seems to be really good in the ice and snow here. I do turn it down to whisper mode but I've left one pedal on for now. Keep in mind that if you feel the rear slipping that that is by design. Ford wants it to feel like a mustang so the traction control will let the rear end slide about 20 degrees before stopping it. I hammered mine in the snow and it does turn to about 20 degrees and just stays there. I can't get it to slip more without being on really slick ice or turning off the traction control.
I thought the factory tires (on the premium) ARE all-weather tires? ?Whisper mode for me and turn off 1pd. Having installed winter tires also makes a huge difference.
You could also consider an all weather tire when replacing the factory tires. Some good ones would be the Michelin Cross Climate 2 or the new Vredestein Quatrac Pro +
I thought one pedal driving would be better in the snow. Isn’t it like downshifting in an ICE vehicle? I thought one pedal driving would be safer since it uses the motor rather than the friction brakes is that not correct?Whisper and 1PD off in the snow. I still usually find mine is a little squirrelly in the rear.
My 17 year old daughter drove in the snow for the first time with me today - first corner she took at dry tarmac speed and I thought "This will be interesting....". Rear end kicked out a little bit but no issues. Pretty impressed actually.If you have snow, there is no better practice than to install true winter tires. Mine handles like a dream with winters.
MME is heavy which can seem like it gives you more traction in snow, but it, and any other car, will slide in icy conditions and it will slide way longer than you want. Winter tires will help tremendously with that, however, don't forget MME is heavy and needs time to stop in the slippery.
I have two teenage boys and a teenage girl and I'm always after them to respect the momentum on slippery roads and slow down with a much more significant safety margin in case things don't go as planned when you slow down (its not just an MME thing).
Winter tires......
For me the instinct is to lift off the accelerator when in a slide. Doing that on one pedal drive would be the equivalent of stepping on the brake a little and that’s the worse thing you can do when you’re skidding. So for me I’ve always taken it off so I can coast.I thought one pedal driving would be better in the snow. Isn’t it like downshifting in an ICE vehicle? I thought one pedal driving would be safer since it uses the motor rather than the friction brakes is that not correct?
Yes and that is a compromise.I thought the factory tires (on the premium) ARE all-weather tires? ?
All drive modes use regen - 1PD is just the most aggressive. As soon as you let off the Go pedal, the car will regen. Friction brakes only kick in at the very end, or in a panic stop situation.I thought one pedal driving would be better in the snow. Isn’t it like downshifting in an ICE vehicle? I thought one pedal driving would be safer since it uses the motor rather than the friction brakes is that not correct?
