- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- MME (delivered 2/26/21), DIY eMiata BEV
- Solar Sales/install
I also had a beyond repair blow out coming back from UT, had to have the car towed as I had no spare. I'm thinking of buying a full-size spare in case it happens again, need to drive long miles on it, eventually to get back home.
really NOT a good idea to drive 'long miles' on a spare, especially with AWD.... even if it is the same nominal size, if the tread wear is significantly different the diameter difference will be enough to be hard on the differential. So, unless you plan on an exact match for the 5th wheel, and rotating it in regularly, probably not a great idea.
