Starting while charging?
Machinator
Alabama
Ford Mustang Mach -e sekect
Today a warning popped up briefly saying something like stop charging before starting the vehicle. Is that a bad idea?
You can’t put the car in run mode (normally accessed by depressing the brake pedal and tapping the Start button) while a charge cord is attached to the charge port. “Starting” the car when plugged in will allow you to access HVAC and infotainment. Once you disconnect, you can start the car and drive it. ??
It's best to read the actual warning message. If you then can't understand it, take a picture of it and post it.
In short, the car was designed so that morons (read "humans") wouldn't drive away while plugged into a charger. People do at gas stations, so they said "hey, let's stop the morons from ripping the charger off the wall and electrocuting themselves or others".
It's proven that people don't read warning messages, ripping off the charging door after unplugging has way too many posts.
VindictivePantz
Arlen, TX
2021 Mustang MACH-E Premium AWD w/ Ext. Battery
In short, the car was designed so that morons (read "humans") wouldn't drive away while plugged into a charger. People do at gas stations, so they said "hey, let's stop the morons from ripping the charger off the wall and electrocuting themselves or others.
Hence the need for break-away hoses at gas stations.
Humans are embarrassing.
dwst480
Dustin
Iowa
2023.5 Vapor Blue MME Premium RWD ER, 2021 Toyota RAV4
I'll own it: I drove away from a gas pump with the hose still in my car a couple years back. I was having a bad day. That's when I learned what a break-away hose was.
Since getting my Mach-E I've actually had a fear of forgetting to unplug my charger before pulling out of my garage. It's good to know that the car would prevent me from doing it.
DevSecNetOps, General PITA
It's not so much forgetting to unplug, it'll keep you from backing out. however the charge door being open won't. A couple people have ripped theirs off or mangled them with the garage door when backing out. (A warning does pop up about it open though.)
VindictivePantz
Arlen, TX
I get it :sunglasses: . I knew as soon as I posted it, within weeks, I'd probably be posting how I need a new charging port.
Art
Art
244SnowyGv932nFordC
Mustang Mach E
Retiref
Just a safety measure. If you forgot that you were charging and drove away, you would pull all of your charging equipment with you and possibly the drywall.
Or worse, like wrecking your all plastic charge port. ??
Scooby24
Olathe, KS
'25 BMW i4 M50; '25 MME GT
Healthcare IT
It would happen! With all the damned dings I totally blew past the warning about the charge port being open still after I unplugged.
CRUNCH, there it goes, popped off (but not scratched amazingly) and put a nice dent in the fender.
We are all capable of being idiots and should be treated as such.
<SNIP>
Yep, I remember driving the Celica into a 510 and getting black flagged. Stupid as heck. But he deserved it. ??
sukhoi_584th
United States
2022 MME CR1 AWD
In this mode does the HVAC run off the HVB? I believe you get the 12 V battery icon which makes things confusing. Shouldn't the DC/DC be active?
