stMache - Blu Max
stmache
stmache
Scott
Leesburg, FL
www.sthomasphotos.com
2023 Ford Mustang Mach-e GTP
Photographer
stmache
stmache
Scott
Leesburg, FL
Photographer
This past week, I finally bit the bullet and have ordered a replacement license plate for Max. Last year this plate was not available, this year it is! Should have it in about 4 weeks or so.
Ford Mustang Mach-E stMache - Blu Max i-QbnV5
My advice for others who want a custom plate, show it to a few people before pulling the trigger. NY allowed my current one (see below). The person's reaction at the NY DOT once she realized why I wanted to change it was hilarious.
Either you forgot to post the original plate at the end of your message, or Administrator removed it for lewdness. (I will always remember the original, Scott!) Either way, I am VERY HAPPY for you to finally get BLU3 MAX.
stmache
stmache
Scott
Leesburg, FL
Photographer
The current plate is in my signature. I forget some people may have that option turned off. Here it is....
Ford Mustang Mach-E stMache - Blu Max i-cHTJ74Q
stmache
stmache
Scott
Leesburg, FL
Photographer
New plates came in and I put the rear one on right away.
Ford Mustang Mach-E stMache - Blu Max i-r7vP5kW-XL
It was too cold (~40F) to put on the Craig's bracket to the front. Have to wait for a good stretch of 60F+ weather later this month or May.
stmache
stmache
Scott
Leesburg, FL
Photographer
With Genie home (see previous message), Max stays outside until late Fall. With rain and possibly snow in the forecast, it gave me a chance to use the MYCAPUCHE Plug Cover for the Mach-e.
Goes on with velcro. The blue color option was a good match for Infinite Blue.
Ford Mustang Mach-E stMache - Blu Max i-kGZLBKD-XL
Snugged it around the charging cord to cover the CCS plug.
Ford Mustang Mach-E stMache - Blu Max i-gBW68bR-X2
Velcro strap uses the Driver's side windshield wiper to anchor it.
Ford Mustang Mach-E stMache - Blu Max i-wJf7Lhp-X2
stmache
stmache
Scott
Leesburg, FL
Photographer
stmache
stmache
Scott
Leesburg, FL
Photographer
AOSK for Mustang Mach E Rear Spoiler (Glossy Black)
The whole idea here is for looks as this spoiler is not functional and I am hoping this spoiler will help keep rain off the backup camera. Will report back if it does or not.
UPDATE: I drove in a lot of rain today and when I backed up, no water drops on the camera. Will continue to monitor but looks promising so far.
This was installed by my detailer at the same time as the Pony graphic (see post before this one).
This one is NOT the V2 version as when I ordered it, V2 was not an option.
A bit dirty here as the ceramic coating was still curing. Will replace with better ones in the future.
Ford Mustang Mach-E stMache - Blu Max i-V3CBfvq-L
I added a bit of processing to bring out more details you see below.
Ford Mustang Mach-E stMache - Blu Max i-ghXQ7xV-L
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
@stmache did you ever get your Craig’s custom plate bracket installed? I just received mine and I’m wondering if you had any sensor problems.
stmache
stmache
Scott
Leesburg, FL
Photographer
I had one on last year. I found I needed to make sure the plate was as close as possible to the bumper or it would cause the front middle sensors to come on at low speeds.
Once I get my Mach-e back from the dealer, I will be putting it back on since the temps will stay above 60 now.
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
Ford Mustang Mach-E stMache - Blu Max 9B632E2E-9218-4178-9975-10838D139EA7
Got mine installed.
No sensor problem and it allows my front stripes to be seen below the nose cone enough to tell that there is a line of body below the “grill”. The factory bracket just made it all look like on big blob there. And the Sto N Sho was way too lo fo sho.
stmache
stmache
Scott
Leesburg, FL
Photographer
Technically not a modification as this was a promised update but finally got Max updated to a 2022 spec software-wise including BlueCruise.
Found out it didn't like me taking too long to take photos.
robbinbadams
Robbin
Houston TX
California Route 1
Electrical Engineer
Back from vacation and putting more miles on the odometer this past week. Got the first 300+ mile estimated range on a full charge today on my RWD Extended Range Premium.
I suspect this will only increase during the next few weeks of summer weather.
I’ve been there and done that in my icbe errw premium. Got at least 325. It’s great.
GreaseMonkey
Chicago, IL
24 Mach-E GT
Got mine installed.
Looks great. Did you run into any issues with the stripes or vinyl wrap? The Craig's web site recommends against installing the 3M tape over these materials. Just wondering cause I'm interested in doing the same.
