Target charge level
PCPilot
Frisco, TX
2021 Mustang Mach E, FE
Ok, so my charging location screen shows my target charge level as 90% and my Charge Session screen shows 100%...
Ford Mustang Mach-E Target charge level D557A7CC-0B19-4C6A-BE6C-ED2CA81104E4
Ford Mustang Mach-E Target charge level 0AA4F31D-9EFA-4258-A7B6-52C41C5551BF
Which one should I believe?
sockmeister
Pennsylvania
2023 Mach-E GTPE
SW Engineer
Are you sure the car is registering as being at the same location you have saved for that charge schedule?
SteelMach
2021 Mustang Mach-E
Mine does the same thing. It'll blow right past 80% and go to 100% even though it shows 80% as the limit (even past 80% SoC), and gives me a "Charge to 100%" button, idk why it even shows that button when it just does it anyway.
I've taken to just going outside and unplugging it when it's nearish 80%.
PCPilot
PCPilot
Frisco, TX
Ya, it says “charging at home” when it's charging. I woke up this morning and the charging was paused, like it often does when charging. If it didn't pause I'm sure it would've gone to 100%.
cmbfod
Arden
FE RR AWD ER
I have noticed the same issue recently. This occurred for me only after the “charge to 100%” and “stop charge” buttons reappeared on the FPA. Prior to that all charging sessions stop at the SOC I had set for the car.
PCPilot
PCPilot
Frisco, TX
It looks like the FordPass app is confused again. Hopefully they retire that thing and develop a real app for the MME.
mpshizzle
Utah
Mustang Mach E 4X
For me it seems to be ok when it says the right numbers in the small text at the top.
IE: "Charging to xx% at home"
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
Have you tried setting this on the big screen in the car rather than the app? Once I used the big screen once, the car seemed to remember the location and start following the app after that.
Try it and find out. It won't hurt anything. Running the experiment will provide much more information than asking folks to guess.
sockmeister
Pennsylvania
2023 Mach-E GTPE
SW Engineer
I have had two different values here as well, but it seems for me that the value at the top in the second screenshot is the true value, as @mpshizzle observed.
Does it work better if u set it inside the car?
Most people have had better results setting the charge limits in the car I have only set them inside the car and have had no issues.
Dylancch
Dylan
Swift current
Mach e
Construction
I use both with no issues. Only thing I can think of is that if they have 2 locations set it might refer to the wrong one? Set all locations to 80%
digdug52
Fort Worth, TX
2021 Mustang Mach-E 4X, 2018 Tesla Model 3 LR RWD
I have 80% set for charging at home (set in the car, not the app) and that value shows as top value in the app. After charging last night it shows the 80 percent I set but the bottom and message says 100%. The only thing I think is it is indicating it reached 100% of your desired charging level at that location (in my case 80%). If this is true, very poor way to message this. Of course, par for the course with Ford Pass, it is just something else that is a bug or not coded to the best intent.
PCPilot
PCPilot
Frisco, TX
Well, I checked the car and the home charge level also showed 90%. I re-saved it in the car and now the app shows 90% in both screens. Jeez.
