Total miles after reaching full charge
Scooby24
Olathe, KS
'25 BMW i4 M50; '25 MME GT
Healthcare IT
The question is definitely reasonable. With the stigma around degradation, everyone's mind first goes to "oh crap my battery is already toast!".
the reality is we've got folks now with 100k miles that still have ~90% State of Health of the battery, and that doesn't exactly line up to how much capacity it still has. (usually higher) so your range impact is not actually 10% lower.
Yes, it sucks that our range suffers due to colder temps. But it's good to know it's only temporary and it is in fact temperature related and not an indicator of poor battery health.
OON7
Evan
New: 24 GT w/ perf. upgrade Vapor Blue // Old: 22 GTPE DMG // 21 Select CG
You are new here, but this is an annual thread tradition once temps drop. It's hard for us to not get triggered. As long as you don't post it again you are forgiven! ?
Cooler temps will impact estimated range, just like a hybrid or ice, the car is just more honest about it. If you are going to road trip, set up departure times if you are plugged in. This will get the battery ready and increase estimated range. Also, use the built-in nav for road trips with expected charging stops as it will precondition the battery for charging as you approach. If you prefer another nav app like Waze, just switch to built-in nav about 30 minutes before getting to the charger and set the charger as the destination.
Generally also going to suggest not charging to 100% if you are doing that daily. The battery is happy with at least a little buffer for day to day driving. This advice may be different if you have one of the new lfp (?) packs, but based on your range guessing not.
The GOM is always a guess, it keeps getting smarter, but just remember that it is always an estimate. Better info/perspective from your miles/kilowatt hour efficiency and overall battery %.
67 Stang Convertible
Rich
Georgia, USA
Physician
This may be old news, so I apologize if it is. I have noticed my total miles after a full charge has decreased since I bought it. I believe I started around 260-270 miles, but now I am only getting 240miles per full charge. Is that normal. Is anyone else seeing a drop in totaliles after each charge?
Hey Josh,
You and I live in the same county in GA. It's completely normal as the temp cools down, you will lose some range (1/3 to almost 1/2 in dead of winter). Normal function of battery tech. Welcome to the forum; just ignore the grumpier forum members.....But, you will see when it's not directed at you; it can be pretty funny!!!
Teslaeata
Nottingham, England, UK
Perfectly good question in need of perfectly good answer, when you get one here I will faint?
My range since new - 29mths & 69,000 miles - has dropped off by a barely noticeable amount at comparable times of year, however the summer/winter difference is between c320 summer and 260 winter on RWD XR.
My 100% was 309 miles until a week ago before the clocks were turned back an hour for daylight saving here last weekend, now at 92% is 248 miles so 100% in the morning will be 270.
So, in answer to your question, time of year/temperatures affects range and age/mileage to a lesser extent, I find.
RWG
Randal
Chaska Minnesota
2021 Mach E
After 22,000 miles my GOM on full charge indicates about the same range. Of course it will decline as our weather gets colder, currently our Minnesota temps are in the 30's to 50's range . We keep our Mach E in a heated garage, never goes below 55, not sure if that impacts the GOM calculation but last winter, range declined with the ambient temps as expected. Not sure if we are experiencing any battery deterioration yet. With our ridiculous Minnesota weather trying to determine true battery range, vs, deterioration vs driving style is a bit sketchy. I routinely pay attention to the trip calculator and try to make sure my MPKW( Miles per KiloWatt) is at least 3. I find this tool is the best real time indicator of how we are doing.
The conventional wisdom regarding lithium Ion batteries is to limit high recharge rates to prevent overheating. Things one can do to preserve/extend battery life:
  1. Try to limit the high speed DC charging sessions. A high Speed DC charger pushes a lot of current back into the batteries, FAST, and that makes the batteries hot which is not good for battery life, long term.
  2. Set your normal charge rate to a lower level. We have ours set at 85%. Since we got the vehicle. It has only been charged on a high speed DC charger twice and 100% charge rate in the garage maybe 10 to 15 times. I estimate we have had about 150 charging sessions so over 90% of our charging sessions did not reach 100%.
Good Luck.
Deleted member 19354
Guest
My guess is weather change. But I believe also the car is doing an analysis on your driving habits?
We had a cold snap a few weeks ago (mid 20s) and lost a few miles
In the dead of winter, losing 20% is normal. More sometimes. Judicious use of heater, precondition battery with a departure time makes it less of an issue.
I knew it! The switch to winter time killed my range!
cryptk
Texas
2023 Mach-E GTPE, Blazer EV RS (reserved)
Just change the clock in your car back to what it used to be and your range will return to normal, easy peasy... documented on page 142 of the owners manual.
Teslaeata
Done it!
Worked a treat.
379 miles in winter, sweet!
Now, just why didn’t I think of that??‍♂
You’re a genious!
Doug&Julie
Douglas
Beaverton, OR
2021 Mach-E Premium LR-RWD
Designer
I made this...if it helps...
Phil-Springs
Phil
Colorado Springs
Mach E CA RT1 AWD Extended DMG 2022
Definitely would be better if we got the best and worst case range. But I’d be happy just for a better description of what inputs the car is really using , so one can adjust based on the actuals for the next driving segment.
