- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
If your lane centering and hands-free BlueCruise stopped working after the 6.13.0 OTA, there is now a software fix available at your dealer. The fix is also being deployed in the 24-PU0105-CMR-FX OTA. The software in the CMR needs to be updated to correct the failure. This only applies to 2022 and 2023 model years.
TECHNICAL SERVICE BULLETIN Inoperative BlueCruise And Lane Centering After An OTA Update With DTCs U2018:51 Stored In The CMR And U0565:86 Stored In The IPMA | 24-2062 06 March 2024 | |||||||||||
Model:
Issue: Some 2022-2023 Mustang Mach-E vehicles which recently received a Ford Power-Up software update delivered OTA may exhibit an inoperative BlueCruise and lane centering with DTC U2018:51 stored in the CMR and U0565:86 stored in the IPMA. This may be due to the software level of the CMR. To correct the condition, follow the Service Procedure to reprogram the CMR using the latest software level of the FDRS. Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. Labor Times
Service Procedure 1. Connect a battery charger to the 12-volt battery. NOTE: To prevent the battery saver mode from activating on the vehicle, make sure the negative cable of the charger is installed on a chassis ground and not the 12-volt battery negative terminal. Do not have the vehicle plugged into the high voltage battery charger during programming. This can cause incorrect module programming. Make sure only the 12-volt battery charger is installed. 2. Reprogram the CMR using the latest software level of the FDRS scan tool. |
