Wonky_Donkey
- Tony R
- Feb 13, 2020
- Norwich UK
- 2022 Mach-E RWD ER
So you're right - basically to apply for the OLEV grant for a home charging point you have to prove that you have a vehicle that qualifies (ie a PHEV or BEV). This means you need the VIN or the registration document for the new vehicle. This is normally all handled by the supplier who will just send you a list of requirements that you need to give the info for before the order for the charge point is handled.In the UK I understand that it is necessary to have an order in place and an indication of delivery before arranging for an installation that qualifies for a grant. I just hope that more information is available when it comes to place an order for the car. As with all things it would be good to have this information now as options could be considered.
I realise some pre-bookers will already have BEV’s and charging solutions in place. I would be interested in the thoughts of others.
Clearly my post does not have the excitement of a test drive or build date! I am making do with slightly more prosaic issues.
I've attached the prerequisites list from my BP Chargemaster install I had done a couple of years ago for my current car. Hope this helps.
