- Mark
- Nov 13, 2019
- Sonora, CA
- Currently: '20 Shelby GT500 FPB '24 Mach-E GTP GGM
- Retired
Erik, since the Koni is only about 1/2" shorter, what problems do you think this would cause in normal everyday driving? It was the closest shock I could get to fit the Mach-E with the mounts and lengths. They have been installed in over 20 MME's and so far have not had anyone complain about over extension or whatever you might call it. One thing that I like about them is I actually got MORE travel out of them than the OEM shocks have which is nice. The body of the shock is shorter so there is a bit more travel.I’m actually working to see if I can have a friend of mine build some 1 inch longer shock mounts that would solve the Koni’s being shorter problem.
Also was going to work on seeing what tension I could reduce from the 15 points of rubber. (Safety and $ being the hold up, and how to make it repeatable for others)
