Rear End Thumping Noise
MICO
Barry
Melbourne, Fl
Mach E, Eruption Green Metallic
I pulled my Mach E out of the garage and started to drive down the road. I heard a thumping sound coming from the rear end, sounding like I pick up a nail or flat spotted tire. Getting out and inspecting the tires I didn't find a nail and both tires looked fine. ('24 Mach E premium with only 15K miles).
Now my concern switched to a potentially deeper problem. Was it the differential? The shocks? Searching the forum I couldn't find anyone with a similar problem; doing a search on You Tube I found problems I didn't even want to imagine
This all happened on a Sunday morning.
The first thing Monday I called my local Ford dealer, but couldn't reach my service supervisor. I made and appointment and figured I would limp into the dealership
I pulled in and proceed to the service counter. Right a way the service supervisor said to me if he knew I was coming in he would have told me what to do to solve the problem.
I seems Ford issued a service bulletin a while back notifying the service techs that after prolong use of the one pedal breaking system, the regenerative breaking system "flat spots" on the rotor and up get a thumping noise that I described. To solve the issue, you simply turn off the the One Pedal Breaking system and make a few hard stops using the hydraulic breaks. He had the same problem in his GT and it resolved his "flat spotting" in no time. I looked at him as I thought he was crazy but said I'd try it.
No sooner that I got in the car, turned off the one pedal breaking and drove out off the parking lot, the thumping was gone. Magic! An easy fix that didn't cost a dime.
Why this hasn't been brought up in the forum or on the internet is beyond me. If this would have happened on a trip, I probably would have call for a flat bed truck and spent money for nothing getting to a dealership I didn't know
Please be aware of the issue and a very easy fix. Once the the thumping went away, the one pedal breaking worked as normal
A simple problem with an easy FIX!!!
SONEWBE
Dennis
Oregon
2021 Job 1 MachE 4X, 2014 BMW X3
Not sure why it didn’t pop up in your search. I did a search for “thumping” and found many threads going back to 2021.
B177y
Olympic Peninsula, WA
'23 J2 MME Premium, '24 Lightning Pro ER, '20 Bolt
Maybe it's like the opening scene of "Goodfellas".
Check your trunk for a "guest".
Ahlarict
B.L.M.
Greater Cascadian Megalopolis
2024.5 60th Anniversary MME Rally Edition - "Shadowfax"
International Man of Mystery
Ken Miles is shaking his head somewhere and muttering something about "Italian tuneups" :)
Thanks for sharing - I wasn't aware of this issue either and I'm a heavy user of 1-pedal as well!
NateZhao
China
MY21 MME Premium RWD
I've encountered a similar situation before. The brake pads and brake discs rusted and stuck together after raining. What I did later was to release the handbrake after shifting into P gear on rainy days.
rhougey
Rich
North California
I’ve never experienced your problem, but I’ve read all kinds of posts and threads about it over the years. It has been a very common problem. Not sure why you couldn’t find the threads.
