What have you 3d Printed?
ricojm
Mt House Ca
65 Mustang, 2021 Mach E
I haven't but our fellow member OhmsLaw printed a pair of very nice little trunk cargo net retainer clips for several of us. These 3D clips keep the cargo net rod from popping loose off the rear hatch brackets. Unfortunately after 8 months of constant use I just broke one of them grrr... he's got a now inactive thread about them hereabouts.
And nearly 2 years ago another member whose name now escapes me printed a very nice charging cover retaining strap which keeps the charging cover from denting the side panel of the car. I still use mine.
Hi Martin, try this guy on etsy for cargo clip, very nicely made and have not had issues like the one from Ohmslaw, look him up as:
Bezaleddesigns
I didn’t print it myself, but I paid to have the charge port door travel limiter 3D printed. I also paid to have the cargo cover retainers printed. Back in the ‘90s we often had rapid prototypes printed off of our Pro/E files. ??
21st Century Pony
Martin
Arlington, Virginia
Bezaleddesigns
Old_Norm
Columbus Ohio
They go inside the bracket of the charge port door to prevent them from hyper extending and denting your front 1/4 panel.
https://www.thingiverse.com/thing:4967291
I mentioned before that that part could lead to a big problem. I printed it in PETG and tried to install it on the door hinge. It broke and became lodged in such a way that the port door would not open more than an inch or two. It took me an hour or more to get it out. I'm not blaming the creator. It was probably something I did incorrectly when installing the part. Just FYI.
Kismit
Julie
Temecula, CA
22 MME Premium ER RWD IBSM ordered 11/6
Teacher
I printed it in TPU and have been using it for almost two years now without an issue
Kismit
Julie
Temecula, CA
Teacher
Actually called a "fender". Hence the phrase fender bender. 1/4 panels are always at the rear of the car.
Thanks apparently I've been wrong about this forever! Learned something new today!
SashaLondon
Sasha
London
MME AWD SR
Hi does anyone have the file for 3d printing the cargo cover clip? I have lost one of the black plastic parts as they constantly come apart.
SashaLondon
Sasha
London
MME AWD SR
Thank you I meant the actual two part bracket that fixes the cloth cover to the car. If anyone has a link or file on how to get this?
OH2AZ2OH
Dublin, OH
Mach E 4X
I printed of few of the low poly Mustangs, but getting the supports out between the legs is a hassle. I had better luck splitting the model in half and then gluing the two sides together. Resin printing would be better for those. Here's the link:
https://www.thingiverse.com/thing:3931883
Not MachE related, but I printed this toggle switch lock that works great:
https://www.thingiverse.com/thing:69806
The outlet my phone charger is plugged into a switched outlet and I got sick of waking up to a not-charged phone when the wrong switch got flipped.
I also printed some inserts for my Costco solar path lights so that I replace the LED pucks with a more standard size.
Other than that, my 3D printer has been a dust collector.
Luke
Luciano
MA, USA
Mustang Mach e, Taurus
Computer Engineer
Jeff-NoVA
Jeff
Northern VA
2022 Mustang Mach-E Premium
