Jerrytball
- Jerry
- Feb 21, 2024
- Gulfport MS
- 2026 bmw i4 M50
- Retired
A somewhat Related question: Does leaving a usb thumb drive plugged in (music) drain the 12 volt battery if you leave it in after the car is off?
I don’t believe it does. The only one that I know drains is when you leave something plugged in the cigarette lighter unless you plug it into the cigarette lighter port or whatever you wanna call that I call it a cigarette lighter port in the very back right of the car, which is switched so turn the switch on and off that’s what I had my window mounted dash cam plugged into it with an extended cableA somewhat Related question: Does leaving a usb thumb drive plugged in (music) drain the 12 volt battery if you leave it in after the car is off?
