12V Battery Availability None
Indy Mike
Indiana
Mach E Prem AWD, 2019 F150, ‘94 Vet, 1948 Willys
Our State of Charge on our 12V Battery is 46% as measured by Car Scanner ODB2 and no Ford dealership I can find has a replacement battery. They all show it as back ordered. Is there a good safe alternative to BHAGM-H3?
KlueBat
2022 Mach E AWD Premium, 2021 Mustang GT
It looks like the part number has been updated to BAGMH3.
Indy Mike
Indy Mike
Indiana
Thank you
Runningslow
Anthony
Madison, WI
2023 Job 2 MME Premium 4X Carbonized Grey
An SOC of 46% doesn't necessarily indicate the battery is bad. Search the forum for maintaining your 12v battery. Mach-Lee has detailed the hows and why's to make sure your 12v battery is sufficiently charged.
What year is your MME?
JeffGo
Washington, USA
2024 MME GT in Eruption Green
Is that a one-time reading? Mine was at 38% Wednesday, drove around and now it's 91% (per Ford owner dashboard). Certainly not looking to replace it.
tbrumleve
Tom
Oregon, USA
The battery will charge, you don’t replace it when it gets low. ? did you get it tested and it’s bad?
EasyPass
2021 MME Premium 4X, 2017 Fusion Energi PHEV
I'm not seeing my 12v SoC on the below link: (just tire pressure, HVB Charge Level, and mileage)
https://www.ford.com/support/vehicle-dashboard
Did you have to take any action to get this on your web site dashboard?
While the car is just sitting, the charging logic waits until the 12V SoC is below 40% before kicking in the charging circuit. If the car is running, the charging circuit kicks in at all times. Note that super-short drives are not long enough in duration to charge the 12V battery from a low SoC, so the SoC may stray downward until it gets below 40%. ??
Indy Mike
Indy Mike
Indiana
2021 Premium Xtd
The_machinist
Russell
2021 Mustang Mach-E AWD ER First Edition
Machinist
What problem are you having that necessitates a new battery? Nothing you've mentioned here seems to.
Indy Mike
Indy Mike
Indiana
OTA updates won’t update after downloading. I get messages that it shut down to preserve battery life when starting in the morning. After charging to 90 % and driving for 20 miles, the most SOC I get is 69%.
