The battery should be at over 85% (or over 12.75 volts) when it's installed and the BMS is reset. If the battery has been sitting on a shelf for more than a year (check the date code or sticker), it should be charged first. If you're unsure if the battery was fully charged when it was installed, connect a 12-volt (4-amp or larger) battery charger for over 12 hours and then reset the BMS.
Resetting the BMS informs the computer that the battery is at 100% charge and has a 35-amp-hour capacity. However, if the battery is not close to full charge when the BMS is reset, it can cause issues because the BMS will assume the battery has a higher State of Charge (SoC) than it actually does, potentially affecting the accuracy of the capacity algorithm.
If the dealer recently ordered the battery from the central parts warehouse and installed it, it's likely only a couple of months old and in good condition. However, in some cases, a dealer may have a battery in stock for a year or two before anyone needs it. In such situations, it would need to be charged first.
if in doubt... install it, leave the mme "on" 24 hrs to be sure battery is at 100%, and THEN reset BMS.
Anton
Anton
Fresno, CA
2021 Mach-E AWD ER
Can you see if i bought the right one? was 455 on ford and on the site you suggested was for 100 bucks lol
Thanks
I paid $180 with labor for replacement via ford mobile service. I’d return that
Was $126, sorry. But very good price to me, will come to Portugal and i have afraid that cant enter in a airplane, just now i thought on this
Dude, I would not share that information on the Internet. Your address, phone, email. Identity theft is a real problem. Just trying to help...
Squire330
Robert
Chester, VA
2023 Mustang Mach-E
Any answer to question wanting to know if there is any external place to store a jumper pack for access in case of 12v battery failure?
