- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- Solar Sales/install
very interesting....Mine was plugged into the provided Ford Mobile Charger, outside in -40C, into 120v
The manual for the mobile charger says it good to -30C
I woke up in the morning to the charge fault, and the car was flat dead in the driveway, last time I drove it was the previous morning.
I just installed a Grizzl-E in my garage to not get caught again
I would hazard a guess that at -40C, the battery warmer could not pull enough juice via 120v (x12amps = 1200-1400 watts thruput) outlet to keep the battery core temp above 0C. If battery internal temp hits 0C I would bet that the charger (in the car) sends a fault to stop charge. Not really a fault with the mobile charger, just a limitation of charging with 120v x 12a versus 240v x 32a
It is BAD to charge lithium if cell temp is below 0C
I would hazard a guess that if you were plugged into 240v 50a outlet, and MME could pull 32amps, it might have been able to keep warm AND charge. So, I dunno if you need a Grizzl-e, but you DO probably need a 240v outlet.
