2024 Mach-E GTPE Window Sticker
Mach1E
I think it’s the rally one. It also has the stripes deletes on the sticker.
It’s confusing for sure.
Would be kinda shocked if it came with that huge spoiler, especially for $0 option.
And the stripe’s confuse me as well because it says “door graphics” and the Rally doesn’t have any stripes on the side or anything like that as far as I know.
Still crazy that you can order one, get a window sticker (which usually means production scheduled) and NOT have any details on the options you’re getting.
LincolnLuvr
VA
currently car-less, but hope to get a MME!
Thanks. I see a couple interesting things ass-u-meing the data on the window sticker is correct.
1. 280mi of range, slight increase in efficiency over the 21-23 GT.
2. Still says 150kw peak charging speed.
3. Has the "MME GT PERFORMANCE UPGRADE" but I don't see anything added to the description that would indicate a hardware upgrade. The "UPGRADED FRT ELECTR-MOTOR" is identical to the language from the 21-23 GT window stickers. I'm still holding out hope it's all software.
Does this mean that the regular GT, sans Performance Upgrade, might have a range exceeding 280 miles?
jvzero find us a regular 2024 GT window sticker! :p
Snakebitten
Coastal Texas
2023.5 Mach-E
For comparison:
This is the 2023 GT with Performance Edition package, AFTER Ford reduced it's MSRP from $67k to $59.7K
(This car still has the original sticker for the original MSRP ($67k) in the glove compartment)
Ford Mustang Mach-E 2024 Mach-E GTPE Window Sticker 1000021956
So are we to believe that the 2024 in the OP, is the 2024 version of this fully equipped 2023?
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
It has a crazy big sticker on the side that says Mach E Rally.
Mach1E
For comparison:
So are to believe that the 2024 in the OP, is the 2024 version of this fully equipped 2023?
Seems so.
But we have to call it a “GTPU” instead!
You heard it here first folks! ?
Mach1E
But the GT isn’t a Rally, so why would someone have to optionally “delete” anything that says rally?
Just seems very odd for a window sticker mention. I could understand stripe and graphic delete on a Rally but not a GT.
You could be right though. Maybe Ford is still figuring out the window stickers. ?‍♂
AliRafiee
Ali
Seattle WA
Software Eng.
I know. I’m just as confused as you are. ?
silverelan
Seattle
The Rally is supposed to have a range of 250 miles and is equipped with 235 x 19in Michelin CrossClimate2 tires. This GT sticker shows 20" summer tires. The efficiency increase is nothing to sneeze at. They took the GTPE from 260 miles to 280 miles.
Mach1E
No more GTPE.
So they took the GT from 270 to 280.
Could just be how they tested it though. Who knows if any actual efficiency increases?
silverelan
Seattle
No more GTPE.
Yeah, I get they removed the "Performance Edition" moniker but it doesn't change the fact that it's the same as a '21-23 GTPE with Magneride and whatnot.
The efficiency explanation is on another thread, courtesy of @Mach-Lee with the new coolant/heating loop and pair of 5-port valves. This is a really stinkin' big deal that required some engineering resources to accomplish.
Mach1E
Yes, but mag ride had nothing to do with the efficiency difference between the GT and GTPE.
It was mostly the wheels and tires. The extra tq might have impacted it some too.
I do wonder if a 2024 GT without the optional perf upgrade and wheels has more range. We should find out soon I guess.
I did see the new coolant info. Didn’t know that would impact range though.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
Retired Engineer
The Rally has "mach E Rally" graphics on the front doors. I'm 99.99% sure this window sticker is for a Rally. That's why it has the stripes and door graphics delete. The only thing that is missing are the fog lamps, but I've no idea if they show up on the window sticker of a Rally.
Ford Mustang Mach-E 2024 Mach-E GTPE Window Sticker 2024-ford-mustang-mach-e-rally-1-64f87f1882d10
Mach1E
That would make sense, but I’m 100% certain this window sticker isn’t for a rally.
Why 100%? I’ve seen both the order guide and order form.
The Rally costs money and isn’t an option on that window sticker.
It also doesn’t come with those wheels on the sticker.
It also comes with the “performance upgrade” standard, while this sticker it’s a paid line item.
The sticker is for a regular GT. 100% ?
Ford Mustang Mach-E 2024 Mach-E GTPE Window Sticker IMG_9867
SWO
MD, USA
Also, the Summer Performance tires aren't available on the Rally.
onepunch
Terry
Tampa, FL
2023 Mach E GTPE, 2023 Velociraptor
self employed
