30% range increase!
ctenidae
Alex
Stamford, CT
Solver of problems
Due to the Global Gerbil and Hamster Shortages, we had to go with Guinea pigs.
They do wonders for the mi/kWh!
Yeah, but you have to enlarge the drain hole in the frunk to handle Guinea pig flow-through. Bypassing the positron accelerator is going to trip the 5 second flux capacitor shutdown, too, so you're going to lose some efficiency there.
Better to stick with the hamster's power density. Unless you can get hairless rats - the cooling savings are huge.
/too far?
ctenidae
Alex
Stamford, CT
Solver of problems
I’m going with the dealer used premium electrons when charging it back up.
ooh, I like that one. "Premium electrons" is pretty good. There's an e85 joke in there somewhere, too.
AllenXS
Allen
Richmond, BC, Canada
Premium Blue ER AWD
/too far?
What’s the anticipated range with the rats and the distance between rat replenishment stations?
ctenidae
Alex
Stamford, CT
Solver of problems
In the more built-up areas like around state capitols and DC, you're never very far away from a fresh pack of rats. A fair number are hairless, a lot of them are balding...
DevSecOps
Todd
Sacramento, CA
CISO
There's no updates available for the MME which increase range (as of 06/06/22).
@rodbin you actually might be on to something. A couple of us are trying to determine why we experienced a 30ish mile increase. The problem is that we performed updates and we are all in EAP. So we don't know if this is the botched rollout of intelligent range or as a result of updating through FDRS.
I'm in 105 degree weather so that's too hot for optimal range.
There might be something here, we just don't know why. Since I'm all for being proven wrong, I'm encouraging further discourse around this.
rodbin
rodbin
rodney
UK
Mache Jaguar Triumph Mini
Coffee
I have had a reply from the ford dealer's expert on the Mach e but it was just the general stuff and did not deal with the fact that the GOM was wrong by 33 miles on a 78 mile journey, whatever the stuff about changing driving conditions etc that is far from acceptable
Jonno21
Derby, UK
Mach-E AWD Long Range Space White
I’m wrong, bad assumption. Last time I was in UK I was too young to drive. Things were being changed to the decimal system.
Just for those outside the UK, we went to decimal currency in February 1971 and finally got rid of pounds shillings and pence. However we drive in miles and fill up fuel in litres. I doubt that we will revert back to (imperial not U.S. gallons) as the true cost of fuel per gallon will be apparent and Big Oil wouldn't want that.
machefan
NJ
Sorry to burst your bubble.
How about today any change?
kidding of course
Ford is testing "intelligent range" to some Early Access members. I got an email on 5/24 that I had received it. Was leaving on the return trip home, so timing was perfect. Noticed no difference. Got an email on 6/9 that the enablement of the feature wasn't successful on any vehicle, so they will try again "in the coming days".
