- Dave
- Dec 21, 2020
- Illinois
- 2021 Mach E4X, 2023 Lightning Lariat ER
I don’t have numbers, but my gut tells me that the higher rates should be slightly more efficient given the constant overhead. There could be circumstances that might change that. For example, if it’s hot and the cooling fans need to run at 48A, but aren’t needed at 32A, then 32 might be better.That is what I assumed. I do wonder what the differential is between 32A, 40A and 48A charging on a efficiency basis.
Its probably not worth worrying about.
