MachyGary
- Feb 22, 2023
- Northridge
- Mach-e California Route 1 2023
It only works with cars that have been retrofitted to support it, which is not a small project.
People bring this point up a lot, but if you get a pack with a bum SoH, couldn't you just.... swap it with a pack with a better SoH?Yea, seems like something for fleet use, where you keep a larger inventory of batteries than vehicles and the vehicle needs to be in use all day long.
The downsides of trading into a battery with a lower state of health would not be worth it for a personal vehicle. At least I would never do it. The EV component warranty on the MachE would be instantly voided too.
Yes. With battery swapping, you don't usually own the battery.People bring this point up a lot, but if you get a pack with a bum SoH, couldn't you just.... swap it with a pack with a better SoH?
In the US this is not yet a thing, BUT in China the company NIO not only sells a massive number of EVs but all their cars do battery swaps and have been for years (they also can just charge). They have nearly 1500 battery swap stations and the swap process takes a couple of minutes. Battery swapping may eventually be the future. NIO only has a dozen so far in Europe and just opened the first station that is a collaboration with Shell.
Could you remotely open the frunk too?I used one of the Ample stations to swap out my battery when I discovered this winter that Ford accidentally installed a standard range battery instead of the extended range battery I paid for.
I sent @Ford Motor Company a message about the mixup, they said that didn’t sound like an experience I should be having, and they asked for my dealership and VIN. Then I was told to take it to Ample and voila. All fixed.
Not in USA, but NIO in China and Norway have battery swap stations.Battery swapping requires special connections for electrical wiring and for the coolant lines, that no cars have today. Those all require manual connect/disconnect today. Additionally, as already stated, the battery mount would have to have a completely different setup than the current pattern that uses bolts.
Then there would have to be come special diagnostics to verify the electrical connections and coolant connections are good after the swap. Also think about the wear and tear on the connections that would be occurring daily.
Remember when Musk did an annual dog and pony show called “Battery Day”? At the 2013 event, he promised to demonstrate swappable battery technology “next year.” Never happened.
I’m not saying this won‘t come to be, but apparently Elon decided that charging a permanent battery was preferable.
