kennelh
kennelh
Louise and Ken
Northern California
alangant
Alan
Plano, TX
MME GTPE Rapid Red (ordered 10/22/21)
kennelh
kennelh
Louise and Ken
Northern California
Monday update: I'm able to get status info again and converted the new info format to work with the existing widget code. I'm not thrilled with parts of it (right now I have to refresh tokens on every request) but at least the status info seems to work. Not everything works; I haven't looked into sending commands and haven't looked at all the fun charging code I added last fall.
One change is lots of JSON fields are vehicle-specific. I've postd on the F-150 forums asking for anyone with other vehicles types to download a test version of the app and send me their JSON data. If you have a non-Mach-E vehicle, you can help here.
Keep up the good work, Ken. I am really looking forward to the widget working again.
alangant
Alan
Plano, TX
I'm also looking for the widget's return! I used it instead of the flaky Ford Pass almost all the time! Thanks Ken!
kennelh
kennelh
Louise and Ken
Northern California
I'm testing out the next GitHub release for the rest of today. With any luck it will be pushed tomorrow. Be advised you will need to log in using your FordPass credentials since none of the previous authentication tokens will be valid. ?
PedroDaGr8
WA, USA
2021 Mach E Premium (First Edition)
Excellent! Looking forward to it!
kennelh
kennelh
Louise and Ken
Northern California
Incoming... let's see how this goes. Remember, only the GitHub version. If it seems stable I'll push a Play Store version.
kodiakng
2023 Cyber Orange 4X Mach-E
trying the github 2024.1.24 version: it appears to get me logged in but i get the "Unable to retrieve vehicle status" when i attempt to add my mach-e. logfile shows 'Unable to resolve "usapi.cv.ford.com" ' mentioned after GET.
would you like issues on github?
kennelh
kennelh
Louise and Ken
Northern California
Thanks, no need to open an issue. I know exactly what I forgot to do ?‍♂ and fixed it.
2024.01.25 or 2024.01.26 coming out shortly.
PedroDaGr8
WA, USA
Just happened to check GitHub and saw you uploaded a new version. This one appears to retrieve the car correctly though the widget shows my car as white instead of red. I will try and get some logs in case you need them.
kennelh
kennelh
Louise and Ken
Northern California
Does the full size widget show your car's image? If not, it can't tell what color to use.
kennelh
kennelh
Louise and Ken
Northern California
Uploaded version 2024.01.26 to GitHub with another critical bugfix. Going to need to add an hour annotation to version numbers soon.
