Cabin Air Filter
I just got a K&N cabin air filter. I pulled out my stock one and it’s still snow white. Being a cheapskate dog, I am not sure I want to replace the filter when it still has a lot of useful life left. Thoughts? ?‍♂??
Ford Mustang Mach-E Cabin Air Filter 2E76B31C-1192-4A38-9B93-9ADE8CDDB507
ChuckA
Chuck
North Branford, CT
Accountant-Retired
Don’t. Do you need to oil up the K&N? If so, I’d return it. Imagine the stink coming through an oiled filter!
I think cabin filters last 30,000 miles.
They have an electrostatic rinse instead of oil. Totally different from their engine intake filters. ??
Not much scent. The cleaning solution has more scent than the electrostatic solution, probably because of the mold retardant and fungicide. That's still a pretty mild scent. Y'all are barking up the wrong tree. ??
bruceski88
Bruce
CA
Mach e
Replaced mine after 1 yr and 13K mi. It had a disgusting thick layer of grey dust. Used the Pure air filter recommended on this site.
dougni
Doug
Central Texas
2021 California Route 1 RWD Ext (Job 1)
I pulled mine out at around 8K and it was time already. Got the K&N in.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
I guess the prevailing opinion is to get the K&N filter. I didn’t realize that the standard filter was so expensive.
silverelan
Seattle
Which filter does the best at getting rid of diesel exhaust and the Tacoma Aroma?
P. T. Magoo
Petersburg, MI
'15 Volt, '22 MME Ca Rt-1
Physical Therapist, Freelance Trombonist
I love the K&N cabin filter! My last few vehicles have had them. You can put the OEM filter in a baggie and store it until the first time you need to clean the K&N. That way if somebody wants to drive the car while the filter's being cleaned, almost no down time.
That said, unlike the K&N engine air filters, the cabin filter can be used while still damp from cleaning, so down time is really a non-issue. I usually keep a 2nd engine air filter on hand so I can have a clean, dried and oiled one ready to go at change time. Not an issue with the MME obviously.
Also, what's to prevent you from spritzing a little of the K&N conditioner (not the cleaner) on your OEM filter and putting it back in? Then you can have another look at it in a few months, see if it's time to change it.
<SNIP>
Hun, I didn’t think of using the original as a spare. I am a dumb doggie! ??? Now to find a baggie for the original one. ??
My OTA keeps failing so I had to make an appointment with the dealer to change the filter. They said they can get it done in 2 or 3 days since they send it off-site for the actual filter element work.
*I hope nobody pays attention to anything I say....
ripperAZ
Ripper
AZ DESERT
I think any air filter is improved by spraying it with Citrace. Citrace is the go to gunk killer for traveling
I have used it for years spray it on the remotes in motels and the area in front of the TV. Guess why.? Hit the phones and the knobs and anything you touch in a hotel room with it when I first get there. Light misting on the sheets after I discard the bed cover up which is always gross. Spray the air conditioning inputs and you have a fantastic citrus smell and a complete kill on bacteria and fungi and viruses.
A couple of years ago I started spraying my cabin air filters with it weekly and it makes a huge difference in the smell of the car and it also kills bad stuff on contact with the filter
I tend to use the cheapest filters to keep airflow high the more robust filters will slow down your airflow and I don’t know if that’s good for the car in general In Arizona I need full airflow in the summer
Jes sayin
ripperAZ
Ripper
AZ DESERT
Jes sayin
Ford Mustang Mach-E Cabin Air Filter F999C194-415B-4610-BED9-536BD333995D
