Cabin Air Filter
I pulled the stock filter and put it in a garbage bag inside the box for the K&N unit. ??
Comparison of the two filters:
Ford Mustang Mach-E Cabin Air Filter 7D1A041E-4DBA-4020-BABD-54CFA279CAEF
Post-filter install decals:
Ford Mustang Mach-E Cabin Air Filter 33E1CF25-7692-4587-B150-404B1D32536D
Decal install took longer than the filter R&R. ??
How easy is it to change the cabin filter?
The owner’s manual covers the filter R&R. The one thing the neglect to mention is to empty the glove box out *before* detaching the pneumatic strut or defeating the travel stops. Paper slid out under my seat. ???
MY21 J1 Premium RWD SR
I tend to use the cheapest filters to keep airflow high the more robust filters will slow down your airflow and I don’t know if that’s good for the car in general In Arizona I need full airflow in the summer
Ripper, does your stock filter look like mine did, or like Poodle's? Jes curious. ;)
His car was built later, after Ford switched over to their "improved" filter design. His stock filter pleat density looks very similar to the Pureflow replacement, just missing the carbon.
You have a good point about max airflow. I'll try to gauge the difference this summer versus last, though it'll be subjective at best.
BTW, I tried to buy Ford's new filter as the replacement but the dealer was out of both (old and new SKUs) and also it was more expensive than the Pureflow so I decided to give the third party one a try.
ripperAZ
Ripper
AZ DESERT
2022 Ice White Mustang Mach E AWD EX BATT
Mine resembles the cheapest white one I buy them on Amazon and five packs for 20 some bucks. They also fit my Kia stinger. My philosophy is at the Cabin environment is pretty good already and a minimal filter with a little treatment and checking it’s better than a big pleated one. I based this on the nerdy MERV ratings for home air filters where they say if you get above 14 MERV You will restrict airflow and heat up your system and run it less efficiently
Who knew Merv Griffin not only did game shows but also air filters
Jes sayin
DevSecOps
Todd
Sacramento, CA
CISO
TRP
Mach E P4x, Ford F150
I've replaced mine twice as well, used the Pureflow filter. Original stock filter was trashed at 8000, Pureflow was toast at 18000. It can be pretty dusty around here and lots of pollen
Just to point out, there are many vehicles that have never had cabin air filters. F-150s for many years had none.
I try not to overthink it. I will change it every 20,000 miles as the manual states. No spray, no special filters. To each their own.
I went with the K&N because it has more surface area than the stock filter and it's washable. After three washings, the filter has more than paid for itself. And no, none of my other cars has a cabin filter, but that doesn't mean I shouldn't take advantage of my daily driver's having filtered HVAC. ??
TonyaE
NC
2009 Ford Flex. 2022 MME premium RWD ER o 1/26/22
RN
Glad you said it.? Never owned a car with one.
ARK
Los Angeles
'21 Premium SR AWD
Highway air is quite toxic, I think filters can play an important role in making it less toxic, also part of the reason why I hate that Ford has programmed the HVAC’s recirculation option to switch off at seemingly every turn.
Source: Los Angeles Times - Freeway pollution travels farther than we thought. Here’s how to protect yourself
Key snippet from the article:
Drive less, and use the 'recirculate' button
Spending time in a car on the freeway can expose you to pollution levels five to 10 times higher than surrounding areas.
Even with the windows up, you could be breathing up to 80% of the levels of pollution found in traffic if your vehicle’s ventilation system is drawing in outside air.
So if you can, live closer to work, use public transit or take other steps to limit your driving time.
“That’s where we still get a big, big share of our exposure, especially if you’re driving very far in rush-hour traffic,” said Scott Fruin, a professor of preventive medicine at USC. “If you can reduce that, it helps a lot.”
When you’re in the car, roll up the windows and set your ventilation system to recirculate. That button can cut pollution to 20% of on-road levels.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
My OTA keeps failing so I had to make an appointment with the dealer to change the filter. They said they can get it done in 2 or 3 days since they send it off-site for the actual filter element work.
*I hope nobody pays attention to anything I say....
Your system thinks your filter is up to date. Have dealer use FDRS.
SWO
MD, USA
I just got a K&N cabin air filter. I pulled out my stock one and it’s still snow white. Being a cheapskate dog, I am not sure I want to replace the filter when it still has a lot of useful life left. Thoughts? ?‍♂??
The only thing that K&N filter will clean better is your wallet.
Sure, in some parts of the country with crazy commuter traffic. LA, SF, Denver, NYC, Boston.
Not when on I-75 headed south. Or driving on the Ohio Turnpike.
I'm not saying they don't help, just that using the new Ford filter and changing every 20k miles works for me.
  • Like
Reactions: ARK
