OH2AZ2OH
- Jan 11, 2021
- Dublin, OH
- Mach E 4X
Yes, that's it. I left mine disconnected for about a minute, but I'm not sure it even needs that long. No loss of settings or PaaK. Your range estimate will get reset, so your estimated range will be lower until you do a few charges. Someone said that they lost their trip meters, but I did not.Hey guys, my car also acknowledges my presence when I approach (lights on, puddles, etc) but front door will not unlock unless I’m using the Fob. Today I learned some try opening the rear door first, then the front. To my amazement, that sequence worked and started the car without the fob. Now I stumbled onto this thread and will try the battery disconnect tomorrow when I have daylight. So to be cLear on page 13, disconnect the 7 trip clips holding down the to
panel, then disconnect the negative, do all on reverse and that’s all? How long did you have the disconnect before you connect again? No having to mess with settings or PAAK re-enrollment?
