buzznwood
- Nov 14, 2019
- california
- focus st & GTPE
The bold is the important part and this is the real issue that I find keeps getting lost in these discussions every time it is brought up, as it quickly get derailed into low speed 0-60 situations away from traffic lights or merging with slow moving town traffic where 5 seconds is enough to cover every day situations.I guess I look at this from a numbers stand point. The F-150 lightning platinum starts at $90k. That's a solid $20k over Mach E GT price. Then there's the F-150 sales numbers. The truck has been Ford's biggest seller forever, so they know there's a huge market for it. Yes, bigger than for the Mach E.
I myself have a Mach E 4x and it moves quite well, both from a get and at highway speeds. I can't imagine the neck snapping the GT gives from a light, and let's be honest, that's where the vast majority of us do this, not at the track.
I'm not hating on anyone that feels they've been duped. I just think you all have an amazing vehicle that some of us wish we had.
Ford will probably make changes in future models, that to is a numbers thing. If sales suffer, changes move faster. That's the nature of the business, keep the customer wanting more, and better. Now go out and snap your neck at a light, and lay waste to an ice vehicle, you'll feel better...I promise.
Cheers!
The key take away should not be faster 0-60s or the 1/4 mile time of a GTPE vs 4x but that the trap speed of your 4x is faster than the GTPE that means for the import upper mind range that you need on the highway the GTPE was accelerating slower than your 4x as it was hobbled by the power limiter.
When you are driving your 4x on the freeway and accelerate you will get a consistent level of performance as the battery discharges cold temps etc you can expect a reduction but this is just one of those EV things.
So in your 4x you could be cruising along on the freeway come up on a slow moving semi so go to overtake it, you want to accelerate up to the speed of the faster moving lane to the left, so you push the go pedal and overtake drop back to the right and lift off to your original speed and carry on a simple everyday maneuver.
While doing that in the GT/GTPE all too often results in have a quick look at the power see you have 90%+ power available due to current sate of discharge ambient temps so ample power to get past the semi in "5 seconds", start the maneuver the power limit kicks in straight away and now 75% of your power meter is greyed out as you crawl past the semi slower than your 4x while another time you do the exact same things and maybe get a couple of seconds before the limit cuts in it is that random.
For people that live is states where freeway speeds are high, the performance hit you get from having 3/4 of your available power just disappearing in an instant means you have to assume this is always going to happen to drive safely you can not drive the same way you would if you had a true 480hp
If you always had 5 seconds of full power while not ideal people would grumble less at present it is only 5 seconds in a very limited scenario which does not include the one where you want it the most which is at freeway speeds where in some scenarios the power limit cutting in could be borderline dangerous.
